What's the best way to find angle of tube for notching ?
Results 1 to 10 of 18
Thread: Tube notching / fishmouths
05-06-2010, 06:28 PM #1
- Apr 2007
- NJ
- 23
05-06-2010, 07:31 PM #2
- Feb 2009
- Lodi, CA
- 1,132
It's been talked about here before, many times. Dig around in this link you'll probably find the answer you are looking for.
05-13-2010, 09:30 PM #3
I don't know if this will help, but there is a free program called 'tube miter' online, look it up, download it.... it will print templates for miter joints on all sizes of tube up to around 3.5". It will calculate all angles, and print temps for connecting different sized tubes together of different wall thickness.
Jonny
Dynasty 300DX
Esab PCM 1000
05-13-2010, 10:38 PM #4
Here is a link for pipe joints, enter the numbers and thickness and just hit submit. It opens a printable page with the template on it. I have never used it myself, just came across it and thought it was worth saving.
http://www.harderwoods.com/pipetemplate.php
Good Luck
Stickmate LX 235 AC / 160 DC.
Clarke 180 EN Just in case
Spectrum 375 X-Treme.
Milwaukee 14" Chop Saw.
4 x 6 Horizontal Band Saw.
Projects and Misc Albums
http://picasaweb.google.com/keesfriend Feel Free to Have a Look ( Just keep in mind I am an amateur )
05-17-2010, 12:41 PM #5
- Nov 2008
- Colorado Springs
- 272
Tubemiter program
here is copy of the FREE tube miter program(runs in windows)
I had "Zip it" to upload it.
Everthing MM but it works pretty goodLive Right Have Fun
XMT350 CV/CC
22A Feeder
MM175
TB302
12vs Extreme
Hypertherm PowerMax 1000
20" x 40" CNC Mills (2)
16" x 60" engine lathe
65 Ton edwards iron worker
3/16' x 24" power slip roll
16' power feed mitering bandsaw
and other fun toys
06-17-2010, 08:34 AM #6
those programs are worthless unless you are notching with a saw or a grinder. if you already know the intersection angle, you know the notch angle too. i just fit up a cage yesterday and eyeballed every notch in the car. every tube fit perfect on the first cut.
LINCOLN IDEALARC 250 TIG
LINCOLN SP100 MIG
15 TON X 4' VERSON PRESS
VINTAGE W.F AND JOHN BARNES 15" DRILL PRESS
WILTON C-2 BENCH VISE
HF 20 TON SHOP PRESS
TONS OF OTHER TOOLS
1956 FORD F-100
1986 OLDS CUTLASS
1969 PLYMOUTH ROADRUNNER
1993 DODGE DAKOTA
1994 DODGE DAKOTA
1998 FORD MUSTANG GT CONV.
2003 DODGE NEON
06-18-2010, 10:21 AM #7
- Mar 2007
- Deltaville, VA
- 2,241
6pak,
Hope you didn't sprain your shoulder too badly, PATTING YOURSELF ON THE BACK.
That really helped the OP I'm sure.Syncrowave 250 DX Tigrunner
Dynasty 200 DX
Miller MM 251 w/Q300 & 30A SG
Hobart HH187
Dialarc 250 AC/DC
Hypertherm PM 600 & 1250
Wilton 7"x12" bandsaw
More grinders than hands
06-18-2010, 11:09 AM #8
i'm not trying to pat myself on the back. I'm just tryig to say that if i can do it, anyone can.
LINCOLN SP100 MIG
TONS OF OTHER TOOLS
1956 FORD F-100
1986 OLDS CUTLASS
1993 DODGE DAKOTA
1994 DODGE DAKOTA
2003 DODGE NEON
07-01-2010, 12:59 PM #9
- Jan 2010
- Calgary, Alberta
- 197
Here is a link to a program!
http://www.cobratorch.net/ttn_dxf
07-04-2010, 03:34 PM #10
- Mar 2009
- Red Deer, Alberta
- 19
I use these http://www.vansantent.com/pipeMaster.htm with ,
I made a set of "jigs" one end has the tubing size I'm fabing about 8" long with the pipe master on it, then I have a second pieace of tubing " I have various lenth's" smaller so it will slide in side the first piece then U can put it in the gap, slide it apart, get your fit with the "pipe master" take it out trasfer it on to you work pieace then do the other end. it works for me. Not perfect and takes a little time but I find its easier than the programs, for the amount of tubing U will waste trying different bends,notches IMO its faster to try it, and it does not fit save it for another project and build another pieace than it is to mess around with a computer.
