I like to know how this all started, wondering if they were trippin pipe or drilling ahead. And how many wells they had punched around that area.
Hate the fact that some have died. When I heard this I shed a tear, I know what it’s like to be up in the tree or on the floor when you get a kick. I’ve had 2 fires back in the day. If they were trippin pipe, that drill string could be a bird’s nest on bottom around the BOP and all hydraulic line severed. Could be why they’re unable to close any of the rams.
Still what a mess. Hope this box works
God bless the missing and there families
Results 11 to 15 of 15
05-07-2010, 01:54 PM #11
- Jan 2008
- So. Cal
- 100
Fab Tech
05-08-2010, 06:15 PM #12
- Jul 2008
- East Tennessee
- 609
The box didn't work according to the ABC World News. Fire was caused by methane gas if I understood correctly. They[rig workers] said a gyser of water shot as high as 240' in the air before the gas exploded. Those that survived are lucky.
Bernard 3500ss water-cooler
Rockwell vertical mill
Beverly Shear B-3
Beverly Shear JR
Home-made English wheel
Milwaukee Porta-band
" Sawz-all
Tennsmith 36" stomp shear
Fixer upper 1982 Lincoln sa200
05-08-2010, 11:13 PM #13
- Jan 2008
- So. Cal
- 100
If that is the case, when they took the kick all the drilling fluid came up out of the hole, when that gas and mud comes racing out of the hole through the rotary table the bushing pop up and if they strike metal that your spark it’s like a giant blow torch. They might of panic, and no one kicked the valves to the bag. Or maybe the Bag didn’t work at all. I know when I was a rough-neck that drill was practice over and over again. Still wondering if they were drilling ahead or trippin pipe anyone know?
Fab Tech
05-09-2010, 07:39 AM #14
They were casing the well. I know 3 guys that worked on the rig, 2 of which were off the other was on it when it blew out luckly he made it off alive.
Miller Dialarc 250
Miller Spectrum 625 X-treme
Miller Bobcat 225
05-09-2010, 02:08 PM #15
- Jan 2008
- So. Cal
- 100
Pipelayer, glad your friends are ok.
This only means that the BOP failed. Running casing is an open hole. The Shear and blind ram should have worked. So here they go finger pointing at Halliburton for setting a bad plug.
Any rig welders out there?Fab Tech
