Results 1 to 10 of 15
    Default The oil spill metal container four stories tall
    I was checking out the metal container they are building to cap the oil leaks. i noticed they were welding it up with either arc or Flux-cored wire feed. Pretty amazing construction. I think they are using Miller and Lincoln. How much you think theyre making?
    Mar 2010
    Campbell's Bay Quebec Canada
    50
    how many portable welders can u spot in the picture =P
    i counted 7.
    Dec 2008
    Arizona
    812
    If they weren't so new looking, I'd look like a Lincoln boneyard.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    2,949
    Lightbulb
    Probably SAE 500's with Stainless Steel cases.
    "Bonne journe'e mes amis"
    Oklahoma
    737
    Quote Originally Posted by forschoolonly559 View Post
    i counted 7.
    Looks like 7 on the ground and at least one ESAB on top.
    Griff
    May 2008
    Mpls, MN
    464
    Owner
    DW Metalworks LLC
    Miller Trailblazer 302
    Miller 8RC Feeder
    Miller Passport Plus
    Miller Dynasty 200 DX W/Coolmate 1
    Hobart Handler 135
    Hypertherm PowerMAX 30
    Smith O/A Torch Set
    Plus more tools then my wife will ever know about....
    Nov 2007
    Southern Louisiana
    421
    That is a pretty big box to just look at it. I would imagine dropping it 5000 feet and trying to hit an area where it will cover a whole leak is going to be quite a job. Compared to the floor of the gulf that box is nothing. Good luck BP.
    Spruce Grove, Alberta,Canada
    583
    Quote Originally Posted by diamondback View Post
    Diamondback I believe the box will be lowered over the wellhead so they can contain what's coming out of the wellhead That is the only leak. the other's they talk about are from the drill stem that broke. But it's only what was in the drill stem that's leaking out. If the BOP's were working the leak wouldn't of happened. Jef
    Nov 2007
    Southern Louisiana
    421
    I just envision the little quarter game where you drop your quarter into a box of water and try to land it on a little piece of plastic to win a drink. An the water is only a foot deep and the box has a small foot print.
    If they are able to do they are some amazing target shooters.
