Results 1 to 4 of 4
    Apr 2010
    Lethbridge, AB, Canada
    32
    Default Welding V-Blocks
    Hi Guys,
    I just finished making my first welding V-block. I need a bunch of these for a project and just couldn't buy them where I live. Frustration leads to invention - and I thought I would share.
    The base is 1X2" channel. I welded on some 1" angle and spaced it off the side by the thickness of my square. This left a gap in the middle for the 2" angle. I carefully ground the top of the channel and the base of the angle flat with my 12" disk sander. I put on an inch of weld to hold things in place as I didn't want to warp the angle.
    Then I cut out the fillet in the angle and ground the front and back flat.
    Here's the finished project. I tested the top of the 2" angle and it was perfectly level with my bench - close enough for welding.
    Synchrowave 180SD
    Millermatic 252
    Hypertherm 35
    MetalMaster 14" Saw
    Other random stuff.
    Salem ,Ohio
    3,974
    Cool
    Great job they look like they will work well...Bob
    Well thought out, a similar construction could be used to make a centre
    drilling jig.
    Jun 2012
    24
    Coburn you built what I had been thing about. Well thought out as well as well done.
