    May 2010
    Default Dolly / Auto Body (not transport)
    Hi,
    I'm new to welding, and this forum - apologies in advance for basic questions.
    I would like to build a dolly for a car shell body (not a road/highway dolly) - but basically a jig with 4 castors that can roll a unibody shell around the garage.
    Ideally, I would like to make the dolly's length and width adjustable, by having tube steel of 3"x 3" x 1/4" slide *over* 2 1/2" x 2 1/2" x 1/4" . On paper, a 2 1/2" square tube (1/4" wall) might slide inside a 3" square tube (1/4" wall). I just tried to place a steel order, and asked if "...a 2 1/2" tube would slide inside a 3 " tube ? - and was told it wouldn't.
    Is there a good source for accurate steel dimensions? Or other adjustability suggestions? Open to someone else's plans as well. Any / all comments welcome.
    Thanks,
    Tom
    Crete Illinois
    186
    You might want to try 2"x1/4" wall tubing and use 2 1/2"reciever tubing....thats the tubing used to make a hitch reciever....it's expensive but it does not have the flash on the inside from the weld joint and I beleive the inside corners of the tubing are a little tighter to afford sliding a hitch into...Jim
    Welding in Crete
    Syncrowave 350 LX
    Millermatic 252
    Millermatic 180 w Spoolgun
    Miller Gold Seal 155
    Miller Elite welding helmet
    JD2 Tubing bender with Hydraulic conversion
    Evolution Raptor15" SteelDry Cut Saw
    Hypertherm Powermax 30
    Some really cool hammers BIG and small
    Traer, IA
    312
    Quote Originally Posted by Vbigdog View Post
    Hi,
    Thanks,
    Tom
    I made a similar dolly for truck cabs and beds. I used 2 1/2 X 2 1/2 X 3/16 wall tubing and 2" tubing to slide inside. It was a little sloppy so I drilled a hole in the 2 1/2" tubing, welded a nut to it, and used a bolt to tighten it down to take the slop out - seemed to work good for me....
    1,569
    For the outer tube use a 3/16" wall as this will give you a little slop. The inside of the tube has a ridge which is why you can't use size on size od/id. A nut welded to the outer tube will let you insert a bolt to tighten it once you have it set.
    May 2010
    MMW, Willy, and Uhohjim,
    Thank you - perfect. This is just the information I was looking for.
    1/4 inch wall maybe overkill for the dolly jig, but I now understand (the seem bead) being the reason my math wouldn't work.
    I appreciate the responses. Thank you. Tom
    Dec 2009
    Northern California
    179
    You may want to google for auto body rotisseries.
    I have seen some plans online for these even though many people sell them for a fortune!
    I got mine from a guy who built his own from a set of plans he found online
    Texas
    279
    I used 3/16" wall exclusive on the rotisserie I built, due to the weld in the I.D. it will allow a small amount of slop, worked well.
    Good luck
    L*S
    Crete Illinois
    186
    Quote Originally Posted by smithbell81 View Post
    I got in an accident a while ago and I've been asking a few people I know if they know of any good auto body shops. Unfortunately, all my friends are drawing a blank. Basically one of my rear panels got a bit banged up and will either wind up being bent back to shape and painted or replaced and obviously painted. Anyone have any ideas?
    auto body
    Where are you located?........would be alot easier recommending someone if everyone knew your location. Jim
    Welding in Crete
    Syncrowave 350 LX
    Millermatic 252
    Nov 2003
    2,019
    Red face Rottisserie/Dolly
    Hi,
    Thanks,
    Tom
    Tom
    here are a couple of pics I found of a body fixture that I thought incorporated a lot of desireable features... The guy that built this one, integrated a lot of featues and details into it that will make it a lot easier and safer for use in a one man shop....
