I was woundering what some of u guys use to sharpen ur tung. I have a benchgrinder but i feel that the stone on it is contaminting it. i have a syn 200 ive dedicated 1 side just 4 tung. when i weld steel and i stop the tip of my tung is yellow. when i took my tig class at school i used a belt sander or the pirhanna. im also still on my 1st box of tungsten its a housebrand i got from my lws. any info is always appreciated.
Thread: tungsten ?
11-27-2007, 08:58 PM #1
- Aug 2006
- holden beach nc
- 26
tungsten ?
11-27-2007, 09:26 PM #2
personally, i use a dictionary to sharpen my tongue. ohhhh... you mean tungsten! Sorry. I lost it there for a sec.
There are tons of posts on the subject. Some like a belt sander while others like a grinder. some stones or belts are dedicated purely to the tung, others arent.
I have a fairly smooth carbide stone that i use for everything and i dont notice any problems yet
sharpen your tips to a conical profile 1.5 times the dia of the electrode.
sharpen in the same direction as the length of the electrode.
slightly blunt off the point or leave sharp.
when using A/C the tip or DCEP the tip will form its own ball.
check this out.. a wealth of info! http://www.millerwelds.com/resources...ur-skills/tig/Last edited by SignWave; 11-27-2007 at 09:28 PM.
Miller 251/30A spool
Syncro200
Spectrum 625
O/A
Precix 5x10 CNC Router12"Z
Standard modern lathe
horizontal 7x12 bandsaw
Roland XC540 PRO III
54" laminator
little dog
11-28-2007, 06:06 AM #3
- Oct 2007
- West GA
- 68
You can look on down the list and find the post I put in about a week or so. And see the things that people posted my on this.
11-28-2007, 07:19 AM #4
- Mar 2006
- Queens NY
- 1,547
This has been beaten to death, a search would turn up lots of good info. i like a diamond lapidary wheel, cheap, easy and fast.
11-30-2007, 08:07 AM #5
Tungsten sharpening jig
This is my version of an idea I got from Flajim over at SFT. It works great and produces consistent, repeatable tips on both my 3/32 and 1/16 tungstens. It was easily made from scrap I had in the shop.
11-30-2007, 04:25 PM #6
- May 2007
- Apache junction, AZ
- 16
i use something called a stilo tig. it spins the tungsten just from the angle you hold it on the grinder. also try using a bench belt sander with a 120 grit belt or pad.
