    Mar 2010
    245
    Default 252 twin rack project
    started this last night,,,, its removable as well, mounts just like the original one
    i still need to cut the wheel axles to size, and tig it up, ill post some pictures after i get it done.
    going to add the pole and gun rack to it too.
    Anything you could do, I could do better.
    I can do anything better than you!
    Lockheed Martin
    Armco Steel, Baltimore
    USW local #3185
    Mar 2010
    245
    more pictures
    Lockheed Martin
    USW local #3185
    Apr 2008
    171
    looks good and you saved over $250
    Mar 2010
    245
    that was my big incentive, it only took one 2x4 sheet of 11 gauge, plus the pipe for the gun holder.
    i may have even improved on the design LOL
    ok,, im going to get back to work on it!
    Lockheed Martin
    USW local #3185
    2,949
    Default "Sister Sledge"
    Hey Stu: 1st pic of post #2 I see a 5# sledge, minus the handle
    Nice cart, think I'll build one for my MM 212. What's the other machine, another MIG?
    I see you're a USW. I was in Local 3-689 in Southern Ohio back in the early 70's (that's when they were OCAW).
    Are you going to make a holder for a spool gun? They want $95 for one new
    "Bonne journe'e mes amis"
    Mar 2010
    245
    yup,, i just got done with the wrap a round arm to hold the pole and a bracket that bolts to the bottom,, no pics yet,, i only stopped in for a break,
    im also using two of the curved bottle cut out scraps ,, for the two sides of the cable holder, so i dont even need to cut those,,, ill post some more pictures in a few hours
    ps: the other miller is a syncrowave 200, and i also have a thermal dynamics cutmaster 39
    Lockheed Martin
    USW local #3185
    Mar 2010
    245
    ok its all done,,, just need to round some corners and tig it up...
    i used 22gauge for the cones,, this one holds 4 tools.
    Lockheed Martin
    USW local #3185
    Mar 2010
    245
    one more shot
    Mar 2010
    245
    ok its all painted,, and it only took a weekend to make
    Lockheed Martin
    USW local #3185
