Results 11 to 12 of 12
    Dec 2009
    Northern California
    179
    I would suggest you remove the tank and have it boiled out by a radiator shop. See if you can find one that will also coat the inside of the tank after it is cleaned and pressure checked
    You can also clean out the tank your self and use Bill Hirsch's gas tank sealer
    Jan 2010
    Calgary, Alberta
    197
    Thats what i was originally planning until i found this DIY kit! Since i'm on a budget, thought i'd go for it but at the same time, i wanna do it right the first time. Still not sure. Oh well, got it running now so will be testing it.
