Results 1 to 10 of 19
    arkansas
    781
    Default 2,600 foot of weld.... 1 giant radiator
    the past few days, i have been contracting to an industrial construction company. they are making a cooler for an aggregate drier "cooler". the finished product was coming out of the cooler still way too hot and needed more surface area. the drum is 36 foot long (only the last 15 feet get the fins) set on 4 inch centers... my big blue pro 300 is getting a decent lil work out as the fins are welded solid weld on both sides to the drum. im still in the fit up phase, so more pics to follow... (btw, the fella in the last pic (part of the construction crew is 6 ft 4 and 300 pounds)..... to give you an idea of the size of this "giant radiator")
    welder_one
    www.sicfabrications.com
    Feb 2010
    Houston, Tx.
    378
    Looks like you have got you're hands full for a while.
    1,916
    I hope you have a wire feeder!
    arkansas
    781
    i have a trailblazer 302 and 12vs suitcase, im using that to tack it all together and for fit up, i have a stand alone feeder on a frame with wheels powered by the pro 300 that i will be running 1/16th FCAW. the fillet on the weld was spec'd to 5/16... i can do that in a decent paced single pass with the bigger fcaw wire....this one is definitely a one time deal, i doubt very seriously that i will EVER weld 3/8 rings on a drum on 4 inch centers.....................ever...
    welder_one
    southern California
    1,783
    That'll surely keep ya outta trouble for a good while!
    How were the quarter circle plates cut?
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    arkansas
    781
    they were cut on a water table by a machine shop in northern arkansas...
    welder_one
    arkansas
    781
    this might be the wrong thread to post this, it should go in the "not so bright" thread, but, it was on this job..... get this.... I'm running 1/16 fcaw with a c02 shield (not a self shielded wire) and the engineer comes over and decides that i shouldn't be using flux core because the breeze was puffing a little bit and that i should be using solid wire mig.... when i told him that both use an inert gas shield over the weld puddle, he abruptly and snidely replied " Well, I am the engineer..." and to which i replied "y'all are paying me by the hour, i'll run 3/32 7018 stick rods if that's what ya want" (they are on a time constraint and need this thing welded out by Tuesday morning) so, its on to 16 hour days until its welded out with .035 solid wire mig...... baaaaaaaahhhaaahhahhhahahahahaaaaaa
    welder_one
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    Quote Originally Posted by welder_one View Post
    You GOTTA be kidding me??? WTF!!! Where did that guy get his papers from a Kellogs box? WOW!!!
    Well good luck with that one, I guess your getting paid by the hour so what the heck!!!
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    arkansas
    781
    they asked for a bid on this and i told them that there was absolutely no way that i or pretty much any other welding/ fab service that would bid it. i said hourly or not at all.... the construction company has used me a bunch in the past, i guess they like my smarta$$edness and my welds
    welder_one
    arkansas
    781
    here's another one from the same engineer that should be on the not so bright thread........ so, i'm welding with solid wire mig 12vs extreme and a pro 300 machine, and the engineer stops me and says that im running too hot... said that i have the machine set at 29 volts and that is too hot for .035 solid wire mig... i tried to tell him that the voltage at the feeder was gonna be less for having 150 foot of lead and 3 tweco style quick connects in line and get this: he says that i should not be having voltage and amperage drop through welding leads, that welding leads wont drop amperage over 500 foot let alone 150 foot.... where do they find these people???
    i do like to run a little on the hot side as the rings are 3/8 and the drum itself is 1 inch thick... 200 amps @ 24-25 volts at the feeder and c-25 mix.... sounds like procedure not too hot
    welder_one
