Results 1 to 7 of 7
Thread: Clean Air
    612
    Default Clean Air
    Is there an air mask, respirator or air make-up system that works well with a welding helmet? I've tried the particle mask (don't know that that helps much anyway), I have a carbon filter paint respirator but it's too bulky. Also anything I wear fogs up my glasses. I haven't had much success with helmet lenses to get the glasses out of the way either. (I don't want to have to remove glasses & put them back on every time I weld if I can help it). Maybe an air make-up system that would pump fresh air into the helmet to purge welding air out?
    Seems like anytime I do any amount of welding lately it irritates my throat. I'm taking that as I sign I better do something about it.
    Thanks in advance for any suggestions. What works for you.
    2,949
    Default Papr
    pro: Click on the products tab, "welding helmets," and you can view Miller's PAPR System.
    "Bonne journe'e mes amis"
    May 2007
    729
    Depending on your application, this is a quality alternative as well:
    http://multimedia.3m.com/mws/mediawe...6EVs6E666666--
    Later,
    Jason
    Professional Spark Generator by Trade.
    southern California
    1,783
    The 3M half mask double filter respirator works good under my Jackson hoods. I use the pink 2191 (or whatever the number is) filters for welding galvanized and they work great.
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    Aug 2008
    Thetford VT
    64
    I use the 3M Speedglass ADFLO helmet.
    Chad
    Trailblazer 302
    Suitcase 12 RC
    S22P-12 Feeder
    HF-251-2
    Spoolmatic 30A
    Maxstar 200 DX
    Shopmaster 300
    S-22A Feeder
    Coolmate 3
    Trailblazer 250G
    362
    3M 7502 respirator works excellent with P100 2097 filters. You will like it.
    612
    Thanks for the replies. I'll check into the 3M mask.
