    Nov 2007
    calgary,alberta
    Default New guy here with a mig problem
    I bought a millermatic 180 about a year ago and have been using it for body work at home,I normally dont weld anything any heavier than 16 gauge metal but the other day i had to do some welding on some thicker(12 guage) material and had some problems,i could not get the machine set properly no matter what i did it would just pop pop pop pop and the weld didint look too bad there was an awful lot of spatter and heavy black soot around the welds.im using .23 solid wire and c25 gas any suggestions would be greatly appreciated.
    Fraser Valley, BC
    593
    Sounds like you voltage is too low for the amount of wire speed (or your wire is too high for you voltage), that would be my first guess. However, it is possible for "popping" to be caused by other ailments. Check to make sure that the wire is feeding properly and you have good gas flow.
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    and a wish list a mile long
    Sep 2002
    Clark County, NV
    2,696
    Did you figure it out yet? Is your polarity at DCEP?
    Fraser Valley, BC
    593
    Quote Originally Posted by MAC702 View Post
    Now why didn't I think of that?
    It is so easy to miss the simple stuff.
    Makita 5" grinder
    IR SS5L compressor
