Results 1 to 10 of 12
    Apr 2010
    Timmins, ON
    8
    Lightbulb Frame mounted motorcycle carrier
    I haven't built it yet as it is still in the design stage. I have posted some 3D renderings of the get-up though. Reason being because there is one slight issue with the design (that I can think of of course). Because the carrier is mounted through the reciever hitch there is going to be some wobbling that will occur because the HSS that goes into the receiver hitch is obviously smaller...any ideas how to fix that??
    Welders always like achieving full penetration with a tight fit in a clean gap
    MIRABEL , QUEBEC , CANADA
    50
    HI
    you drill a hole on the side of the receiver hitch , weld a nut and as you tighten the bolt it squeeze the hss and it stop moving .
    Bobby
    FABRICATION-CRATION K ZEN
    MILLERMATIC 210
    SPOOLMATE 3035
    SYNCROWAVE 200
    HYPERTHERM 360
    Apr 2010
    Jackson, MS
    79
    Since you have the welder, why couldn't you modify the hitch to have a receiver on either side of the one in the middle? That way, you can have three inputs on the motorcycle bracket that would eliminate any torsional movement of just one. I wouldn't think it would interfere with the car bumper that way.
    MillerMatic 252
    Spoolmate 200
    Diversion 165
    Spectrum 625 X-Treme
    Dayton 6" Miter Band Saw
    Delta Drill Press
    Bosch 10" Table Saw
    Jet 5 Ton Chain Hoist
    Radnor O/A
    Apr 2010
    Timmins, ON
    8
    Default Thanks
    Yah those are both really good ideas. Thanks for the help
    southern California
    1,783
    The dual receiver idea does work very well. I built a cargo carrier for an RV trailer and used dual receivers and the thing is very, very stable in all directions. 2 receivers is plenty, no need to go with 3.
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    southern California
    1,783
    I also build motorcycle carriers. Here are a few different designs I've built.
    Millermatic175
    HTP MIG200
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -Bobcat 250NT
    -PassportPlus/Q300
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    Apr 2010
    Timmins, ON
    8
    Desertrider33 did you have any issues with wobbling with your design?
    southern California
    1,783
    JJF, the single tube designs do wobble in the receiver tube. I use a Draw-Tite J-pin in my hitches to keep down the wobbling. There are also other anti-rattle devices you can buy to keep the hitch from wobbling. Check out www.e-trailer.com in the hitch acc'y section to see various anti-rattle devices. Or look up the J-Pin on the www.draw-tite.com website. The J-Pin is similar to K Zen's welded nut and set bolt idea for tightening the tube to one side of the receiver.
    Here are links to write-ups I did on the carrier projects with lots more pics and description of the designs.
    http://weldingweb.com/showthread.php?t=36222
    http://weldingweb.com/showthread.php?t=40914
    Millermatic175
    HTP MIG200
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -Bobcat 250NT
    -PassportPlus/Q300
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    Apr 2010
    21
    JJF -- You might also take some thin flat stock, weld it to two adjacent sides of the square tube, and then grind it down so that the fit into the receiver hitch is tight with little movement. While this would be easier than two receiver hitch points, the dual receiver set up is the best thing for creating stablility.
    Bill
    Miller Bobcat 225
    Apr 2010
    Timmins, ON
    8
    Great ideas thanks alot!!!!!
