Was watching "Ultimate Factories" on the Audi R8 and was amazed to see that they mig welded the chassis together by hand..
here is a link to the show
http://channel.nationalgeographic.co.../4544/Overview
and here is a link from icar on welded alloy chassis..
http://www.i-car.com/pdf/advantage/o...008/051908.pdf
Could not find out what type of welders that Audi uses... anybody have any ideas??
thanks
Heiti
Results 1 to 10 of 15
04-26-2010, 11:39 PM #1
- Nov 2003
- 2,019
Audi R8 Hand Welded Aluminum Chassis
04-27-2010, 12:43 AM #2
- Feb 2007
- 62
What welding machines?
Haven't seen the show, but in the one still image, they look like "Fronius" welding machines. Austrian made and quite sophisticated electronics, I believe. Some US market penetration. Try http://www.fronius.com/cps/rde/xchg/...s.xsl/3022.htm. The only problem (I consider it a problem) is that almost all TIG machines made outside of the US market are based on a torch mounted amperage control. I'm a tried and true "Foot control" TIG welder. I have an ESAB with hand control and just don't like the lack of control I get with the hand switch.
04-27-2010, 04:15 AM #3
- Nov 2005
- 130
Maybe I'm wrong but it looks like they're mig welding.
04-27-2010, 08:25 AM #4
- Feb 2007
- 62
Rambling reply
Sorry,
I was just rambling about European welding machines in general (TIG). They are MIG welding, and I still think those are Fronius welding machines.
04-27-2010, 10:58 AM #5
- Nov 2003
- 2,019
Stillwelding
might very well be Fronius machines... have some info that i-car developed their aluminum car structural repair program in Appleton, Wi. maybe using MM350P machines??? wouldnt mind some input from Andy or somebody from Miller.....
Also
while skunking around for this found some cool Al design info .....
here are some links...
http://aluminumintransportation.org/.../at6manual.pdf
and here an industry group.. lots of info..
http://aluminumintransportation.org/...ut-us/about-us
my MM350P and Alumapro would be right at home.....
04-27-2010, 08:26 PM #6
- Feb 2007
- 62
Thanks for the PDF file attachment on the Aluminum extrusions. Also, I looked at the video in the link from the first post, and those are definitely "Fronius" equipment. Red and white with a Fronius label on the side. I wouldn't expect much other than Fronius.
04-27-2010, 08:54 PM #7
- Nov 2003
- 2,019
Could be....... Fronius was not sure, I exchanged notes with them today.. they will get back with me.... still think a MM350P would be about right..
04-27-2010, 10:13 PM #8
- Nov 2003
- 2,019
ALCOA Aluminum automotive structures
For what it is worth... lots of the engineering for these structures.. Audi, Ferarri, Jag etc... is ALCOA in Ohio... U. S. of A..
http://www.alcoa.com/aats/en/product...sp?cat_id=1527
04-29-2010, 12:35 PM #9
- Nov 2003
- 2,019
More and more aluminum in automotive structures... and many will need repair...
http://www.search-autoparts.com/sear...l.jsp?id=58064
and i-car is starting to qualify people for that welding ability..
http://www.i-car.com/html_pages/trai...wqt_info.shtml
04-29-2010, 11:54 PM #10
- Jun 2009
- Auckland New Zealand
- 12
Well Stillwelding it may be time for you to do a bit more research about non USA manufactured welding equipment.I believe nearly all brands of tig welding equipment produced outside the US are available with foot controls.Also most of the European manufactured machines are technically further advanced than US equipment.I have a 230 amp single phase AC/DC tig manufactured by Kemppi in Finland.It also has the ability to weld Ali in a mix of AC and Dc.
Have a look at Kemppi.com.Also German manufacture EWM machines
