Results 1 to 10 of 16
    Raymore Missouri
    1,906
    Default Home made air cylinder
    Ok guys, those of you who are familiar with me, know how I like to make stuff. I have always been fascinated with hydraulics. Here is a cylinder I made from scrap material. A lot of you have lathes and making a piston or a rod or an end cap is not much of a chore. But...trying to make the cylinder with a smooth bore that is accurate is difficult if not impossible for the home shop.
    My neighbor had a new deck put on the front of his house and for ballisters they used 3/4 inch round black aluminum tubes. There was scrap left over and being who I am, I saw visions of what I could make. The tubes are 3/4 inch OD... .654 ID with a very smooth bore. On the box it said this was 6061 extruded aluminum.
    With this size bore and at air pressure of 100 psi you can expect about 33 lbs of push from this little cylinder, which is more than enough power to open large tool box lids, robotics, etc (your imagination is your only limitation).
    The first pictures show the end caps I made from aluminum and the rear end cap and piston have been grooved to accept O rings to seal better. This is a single acting cylinder and no seal at the rod end. The rod is 1/4 inch.
    The threaded hole in the rear cap is 1/8 inch pipe thread which is very common. The fitting is 1/8 inch pipe thread on one side and 1/4 inch compression fitting on the other which makes it very handy to use 1/4 inch aluminum, copper, or flexible plastic line for your air supply. The last picture shows the cylinder assembled. There is no rod end because I have not yet decided how I will apply this.
    At first, I had thought I might TIG the caps on but I was afraid that I may slightly distort the cylinder from the heat. If you will notice, on the end caps, enough of the cap is inserted into the cylinder that I could pin it in place with 1/8 inch roll pins. That is why I put an O ring on the rear end cap and the pin is between the O ring and the brass inlet fitting.
    One good thing about finding this resource (as far as the cylinder) is you can custom make any length you need to fit your exact need. I am going to check into a larger ballister tubes for more power.
    I hope some of you will find this useful.
    PS I suggest you use a restrictor orifice at the air inlet so the piston/rod will slam out too quickly.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    COOL PROJECT.
    it looks like the cap's are long enough you could TIG the lip at the end without distorting into the slide portion of the tube. it would no longer need the seal if it was tiged closed, so you would not need to try to keep from melting it, just keep the slide clear of the heated end as you were TIGing it. although that would make it impossible to service if it was TIGed closed. so maybe its better the way you left it.
    so what do you think it will end up on ????
    Raymore Missouri
    1,906
    Hey Fun............If you remember some months back I put a post and a link to a youtube video of my r/c 4 wheel skid steer bot as I call it. The entire top
    swings forward like a cab on a 18 wheeler. Whenever I need to get to the inside I prop it up with a stick of wood. Rather redneck.....huh? Since it already has an air tank on it for the front forks, it could also lift the cab. How cool would that be. Kind of like a lowrider bra! If you need to refresh your mind go to youtube and put GOT BOT? in the search bar.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    Jul 2007
    Lancaster, Pa
    431
    Nice job Monte. Be interesting to see it in action.
    Hopefully I have the time someday to play around a little more and experiment like that.
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    Raymore Missouri
    1,906
    Quote Originally Posted by KBar View Post
    Are you talking about the cylinder or the BOT on youtube?
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    STUCK IN DIAL UP HE--. no you tubeing for me.
    got a still shot of it ??
    sounds like a good plan to lift but will the home made tubes hold without sustained air flow ?? how good are the seals ??
    Jul 2007
    Lancaster, Pa
    431
    The cylinder and the BOT. I have an old golf cart I want to rip apart. Plans were to make a little dump truck with dual axles. That fell by the way side for now.
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    2009 FXDC
    Raymore Missouri
    1,906
    Default Still photos of bot
    Pictures inserted by Mrs Nick, so he may come back and edit this.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    Raymore Missouri
    1,906
    Default Still phots of bot, two more
    Notice the "High Tech" board I held up the bot cab with. I hope to replace this with the air cylinder I just made.
    Photos inserted by "the Mrs."
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    Vancouver BC Canada
    605
    nice to be able to see under the cover. Looks like alot of fun and challenge.
    What are the two servo's on the front right corner running? how many channels do you need for this app? 4 or 5?
    whats just to the left of the reciever and at about the same hieght?
    are those grey cables to feed the motor(s) ?
    if I may offer a suggestion, reroute the inter battery connecting ground wire and pass it under the diehard's + post. the ground looks as if it is sitting on top of the diehard + post. That could spell disaster.
    All in all a nice rig Nick. Do you think you'll ever enter a robowar competition?
    one day i'm going to make one too. I could have picked up a mobile electric seniors chair the other day. I didnt and now im kinda kickin myself. It was a battle of space and time. I have neither the space or the time right now..
    too many planes and cars and boats and work and homework and life and and and
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
