    Apr 2010
    Default Trailblazer 302 and Aluminium TIG???
    Hello all, my first post. Been reading on here for a while and decided to join in!
    I have a 2008 Trailblazer 302 an Id like to know if I can do aluminium tig with it, with or without any attachments. Im looking to go the cheapest route possible as it wont get used often.
    southern California
    1,783
    Use the machine in AC and hook up an HF251D1 high freq box, pedal, torch and argon and you'll be tig'ing aluminum with your Trailblazer.
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    Apr 2010
    Okay thanks! So I cant just use ac on the welder with scratch start?
    8,180
    Sure, but you'll have a real unstable arc that'll wonder everywhere.
    southern California
    1,783
    You need the continuous high frequency to run it in AC for tig'ing aluminum. That's what the HF251 box provides, as well as a gas valve that operates via the remote, which is nicer than a manual gas valve on the torch.
    Alternatively, you can just buy a portable inverter tig, like a Dynasty 200 or Thermal Arc 185 or Diversion and plug it into the Trailblazer's 240v outlet. I use my TA185 with my Bobcat to tig aluminum from the truck and it works very well.
    Millermatic175
    HTP MIG200
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -Bobcat 250NT
    -PassportPlus/Q300
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
