Results 1 to 10 of 17
    Near Great Smokies Ntl. Park
    60
    Default Should I rebuild or not on Big 20 welder
    Hey Miller Guys
    I works with Salvage (rebuildable cars) Yard -my boss brought the Miller Big 20. The guy told him that that welder had bad or cracked head gasket of the engine. It won't run..I don't know what do with them?
    I should fix or have rebuild on the engine? How cost the engine rebuild kit would? Or Take it to Metal/Scrap yard?
    What is your suggestion?
    MillerMatic 211
    60
    Default part2
    more pixes
    MillerMatic 211
    Lake of the Ozarks MO
    3,594
    Nice pix dude.
    Welcome to the forum
    I think you should rebuild it if you can do the labor yourself. If not you may wanna put it on Craiglist.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    8,347
    Can't really see it being the head gasket on an L head. Probably just siezed. Does it turn over at least?
    Jul 2006
    1,508
    Can you post a picture of the faceplate? If it's what I'm thinking it is, they weren't much of a welder setting on the showroom floor.
    Caution!
    4,494
    Is it worth it? It would make a big difference if it was a blown gasket vs a cracked head. Lots of running units around compared to putting a fresh engine in this one. If you need it thats a matter, or if you will run it long enough to pay or if you sold it tomorrow could you recoup the effort?
    Mar 2010
    South Dakota
    19
    I'd pull the head off see if it's a cracked head or just a blown head gasket....blown head gasket is a cheap fix....cracked head you could find out what other equipment uses that same engine and maybe find one in the junkyards. small skidsteers, aircompressors, ect. should be a tag on the engine...get the make and model and google it to find out what other things used that same engine.
    Bobcat225g plus
    8VS suitcase feeder
    Syncrowave SD180
    Miller CP250-TS S-52A Feeder
    Lincoln SP100 mig
    14x40 engine lathe
    bridgeport mill
    torch, plasma cutter, grinders, drills, and all that stuff
    Aug 2008
    Orange, TX
    1,223
    Continental Red Seal F163.
    Way too easy to fix and the unit in way too good of shape to scrap. I say fix it.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    3,594
    Quote Originally Posted by duaneb55 View Post
    That was pretty much my assessment as well. Even if the welder part was junk I would still keep what was left of the engine.
    Miller WC-115-A
    Miller Spectrum 300
    4,494
    Are we a compulsive junk collector?
