Results 1 to 7 of 7
Thread: 350p
    Vernon Ct
    118
    Default 350p
    Does anyone have one? I'm thinking about getting one with the XR gun. Any input would be good.
    Mike
    MD Welding & Fabricating L.L.C.
    mdwelding@sbcglobal.net
    ****inson ND
    557
    Talking
    A truly wonderful machine! If you can afford one then I'd say go for it.
    Feb 2006
    19
    We have one at work, great machine,havn`t used the xr gun we have the roughneck on ours.
    So. Cal
    335
    Default Yep got one!
    Got the 350 & XR gun. Very heavy duty, not much you can't do with this set-up! We don't use it often and break it out when the 252 is in jeopardy! The pulse weld feature as you know if you have ever used it is awesome and we find ourselves using it just for that on many projects!
    Great welder & gun combo you can't go wrong!
    We depend On:
    Burco/Koco | Onan | BobCat
    We belong to or support:
    American Welding Society
    The Welding Institute
    Anderson & Co. LLC
    Metal Cr
    afters
    Vernon Ct
    118
    Default Invision 350?
    Anyone using the Invision 350MPa? How is that compare to the 350P?
    It's nice asking here before I call my LWS.
    Mike
    arkansas
    781
    don't know much about the invision, but the mm 350p is truly all the wire machine you'll ever need. i have used it with a 30 xr gun, but mostly it gets the bernard q-300. i have gotten the fan to turn on a couple of times and then it's only after using spray transfer for a while. not a big fan of the pulse feature, but that's just me. great machine.
    welder_one
    www.sicfabrications.com
    Nov 2007
    Southern Louisiana
    421
    Default 350 p
    I used the 350 p to teach welders in a lab and it was great. We also used a python gun for aluminum and it was smooth. I think the xr gun would be even better. Miller has dvd's on their stuff so get a hold of the liturature department up there and they can get you what you need. I saw the invision 350 MPa at the show in Chicago and got to use it. It is amazing how easy it is to get your settings right. For pulse welding you can set the average voltage now instead of worring about trim. So you set it up like a regular mig machine but then it pulses. It will be interesting to see if they can do something to beat this machine.
