Done with school. Starting my first project. I have a set of stainless turbo headers to build anyone have any tips on back purging? Dos dont's tips on cheap tube adapters for sealing and introducing the gas for back purge.
Results 1 to 10 of 11
Thread: Stainless tube
Hybrid View
04-20-2010, 09:02 PM #1
Member
- Apr 2010
- 78
Stainless tube
04-21-2010, 02:43 PM #2
You can buy some relatively inexpensive, but there's no need to unless you just want a new toy. Tape some cardboard over an end, punch a hole in it for your argon hose to enter, put another piece on the opposite end with a small purge hole in it and weld away.
Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
04-21-2010, 05:57 PM #3
- Apr 2010
- Newport News, VA/Fremont, OH
- 182
I've never used anything fancy, either. I do sometimes tape an old clear lens on one end so I can look inside and check for penetration w/o peeling the tape off all the time
04-22-2010, 09:56 PM #4
Aluminum foil works well for capping tubes for purging, It conforms around the bends well. I also use aluminum tape quite often.
Jonny
Dynasty 300DX
Esab PCM 1000
04-24-2010, 03:54 PM #5
Member
- Dec 2009
- 33
I love the clear lense idea! No more re-taping for me to check penetration!
Ur a genius hockey guy nick!
04-24-2010, 04:02 PM #6
Member
- Dec 2009
- 33
Stainless Steel Wool works good to!
I usaully tape out in the field, foil and steel wool can be easily lost inside a pipe.
Turn your main piece of tape sticky side out,then add a few small strips to hold it. Else you'll have a mad fitter cleaning off glue.
