Results 1 to 10 of 11
Thread: Stainless tube
    Default Stainless tube
    Done with school. Starting my first project. I have a set of stainless turbo headers to build anyone have any tips on back purging? Dos dont's tips on cheap tube adapters for sealing and introducing the gas for back purge.
    Dec 2008
    Arizona
    812
    You can buy some relatively inexpensive, but there's no need to unless you just want a new toy. Tape some cardboard over an end, punch a hole in it for your argon hose to enter, put another piece on the opposite end with a small purge hole in it and weld away.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Apr 2010
    Newport News, VA/Fremont, OH
    182
    I've never used anything fancy, either. I do sometimes tape an old clear lens on one end so I can look inside and check for penetration w/o peeling the tape off all the time
    Jun 2006
    Calgary, Alberta
    377
    Aluminum foil works well for capping tubes for purging, It conforms around the bends well. I also use aluminum tape quite often.
    Jonny
    Dynasty 300DX
    Esab PCM 1000
    I love the clear lense idea! No more re-taping for me to check penetration!
    Ur a genius hockey guy nick!
    Stainless Steel Wool works good to!
    I usaully tape out in the field, foil and steel wool can be easily lost inside a pipe.
    Turn your main piece of tape sticky side out,then add a few small strips to hold it. Else you'll have a mad fitter cleaning off glue.
    Apr 2010
    western colo/southeast wisc
    9
    cool something i always wanted to do. can you post some pics
    Auckland, New Zealand
    26
    Bring your purge hose in the bottom and vent out the top. I purge with about 5 or 6 litres /minute on the flowmetre. Guessing yours reads in cubic feet/hour???, but anyway, if you have too much gas inside, it'll push your weld out, and even if not too that extent, you just use more gas than you need too.
    Jul 2008
    East Tennessee
    614
    Quote Originally Posted by kelzweld View Post
    I do the opposite , purge top vent bottom. Argon is heavier than air.
    Bernard 3500ss water-cooler
    Rockwell vertical mill
    Beverly Shear B-3
    Beverly Shear JR
    Home-made English wheel
    Milwaukee Porta-band
    " Sawz-all
    Tennsmith 36" stomp shear
    Fixer upper 1968 Redface Lincoln sa200
    Powcon 300st
    26
    Quote Originally Posted by Showdog75 View Post
    I've never tried it that way. Was taught many years ago to do it my way, and the welds comply with NZ dairy industry standards, so thats the way I do it. If you follow this link, on page 1, the paragraph titled 'purging procedure' lists the same reason as I was taught. I'm not saying your way doesn't work, just that myself, and many others were taught to do the opposite.
    http://files.aws.org/wj/2006/12/wj200612/wj1206-38.pdf
