Results 1 to 10 of 16
    Jun 2008
    9
    Default finished my table
    Gave someone my design and they drew it out and laser cut the top out of 3/8", its 30" x 60". The x pattern spec was from a member here, and I bought the Miller Xclamp to use. There is a bunch of 9/16 holes as well, can't see all of them due to the crappy cell phone pic. Height is around 34". Made a tray for random junk, stainles tubing on the sides for hanging things, and adjustable feet due to my unlevel shop. Add a $3.99 can of canadian tire rust paint (okay, it was a can and a half) and done like dinner. Came out pretty good I think. Can't wait to use the TIG on this as opposed to my wooden folding table with a piece of warped 1/4" plate resting on top.
    Matt
    Mar 2009
    234
    Nice table. I'm assuming the hole cut at the end of each slot means you can lift the clamp out and move it?
    Jun 2008
    9
    Yep you bet, the clamp just goes in the hole and then you slide er up and down. and I just realized those vice grips on the right look like they are on the ground, they are actually on the right 'tray' that is expanded metal grate or whatever its called.
    May 2008
    OCEANSIDE, CA
    123
    Nice table. How much did it cost to get the top cut if you don't mind me asking? I realize that it'll probably be twice as much here in SoCal (unless you're in SoCal too), but I was just curious, because that's a really nice feature. I was thinking of doing slots as well.
    DYNASTY 200SD
    COOLMATE 1
    MM140AS
    SPOOLMATE 100
    SPECTRUM 625 X-TREME
    SPECTRUM 125C
    Nov 2008
    Kansas City Metro
    387
    Nice looking table, almost might make a guy not want to use it.
    Great work.
    Tom
    Stickmate LX 235 AC / 160 DC.
    Clarke 180 EN Just in case
    Spectrum 375 X-Treme.
    Milwaukee 14" Chop Saw.
    4 x 6 Horizontal Band Saw.
    Projects and Misc Albums
    Dec 2008
    Fort Worth, TX
    28
    Great looking table!!! I like the slots for clamping too great idea!
    Jack I just spent about an hour looking at your garage that's cool dude!!
    Tim
    May 2007
    Dallas, Texas
    323
    Quote Originally Posted by Hydro View Post
    Tim
    Jack,
    Nice write up on the garage. Your garage makes mine look like a garbage dump.
    Charles
    Millermatic Passport Plus
    Millermatic 350P with Python
    XMT 304 /w S-64 feeder and 12VS
    Dynasty 300 DX
    Thermal Arc 400 MST
    Premier Power Welder for my trail junk.
    Mar 2009
    234
    Thanks, guys. It's not usually all cleaned up like you see in the photos, but I try and get it back to the starting point in between projects.
    Gratuitous picture:
    Now, if I could only find room for a welding table with clamp channels in it, like crawler.
    Oct 2008
    Texas
    52
    sorry but what are the X cutouts in the table top for?
    May 2007
    Dallas, Texas
    323
    Quote Originally Posted by jackh View Post
    Miller Xclamp.
    Dynasty 300 DX
    Thermal Arc 400 MST
