Results 11 to 20 of 24
    Jan 2010
    Brooklyn, NY
    73
    Quote Originally Posted by ElementFe View Post
    Look at those outrigger supports, it's pretty easy to see why they don't give you much rigidity- any time you have flat bar in an assembly it's going to flex unless you have something to stop it- using angle iron or (as someone said above) a larger solid bar would be rigid- it can't really do the job it's asked to do as assembled.
    Also, when you're doing braces like that, think in terms of triangles- it's the simplest geometric form that's rigid, most framework is designed with that in mind.
    Looks fantastic, though, my wife would be beside herself if I built her something like that!
    Andy
    I definitely get it on the triangles, that's why I was thinking of a gusset on the weld tab. What i'm seeing is the flex is not in the diagonal but in the weld tab itself.
    Any thoughts on pre-loading the railing? In other words, breaking the welds on the top of the outriggers, pulling the rail an inch or two out of plumb, then welding them back.
    I'm also thinking of breaking the welds on the weld tabs and puliing them in closer to the wall so they exert less leverage on the weld tabs.
    "A little bit of knowledge is a dangerous thing"
    Millermatic 135
    Milwaukee 14" Dry Cut Saw
    Milwaukee Deep Cut Band
    Fully charged fire extinguisher
    2,949
    Default NYS Stair and Handrail Codes
    Matt: Do a Google search www.inspectapedia.com for NYS Stair and Handrail Codes.
    You could fiddle around, doing this and that, and it still not be right. When it's built to Code Standards, there's no question as to it's strength and uniformity.
    "Bonne journe'e mes amis"
    WY...armpit of U.S.A.
    636
    Cut your losses on the angled uprights and go with straight upright standoffs that won't allow flex.
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    Lodi, CA
    1,126
    Do what Roy suggested, but set it off a foot or so, cut and angle the vertical tube down to the lower mounting point (against the side of the concrete). Like he said, vertical tube should be the same size as the first post, bolted at ground level. Use square tube for the offsets, doesn't matter what size, 1" would be appropriate, whatever looks good. Bring the vertical members a foot or two higher than the railing, mount lights on top, wired into your porch light. Use 12v lawn lights if you're worried about shock hazard.
    This would look like it has a purpose, other than holding up the railing, and you can very discretely bring the wires up thru the vertical members.
    I'd make a picture, but I can't do autocad as good as Roy
    Jan 2010
    Brooklyn, NY
    73
    Thumbs up The light bulb just went on...
    Quote Originally Posted by WyoRoy View Post
    AAAAHHHA!!!!
    Now I get it!!! Thanks. That makes total sense. It's that whole picture/1000 words thing. I will post up some pics after the fix!
    Separately, thanks to all for the kind words.
    Matt.
    Millermatic 135
    Lodi, CA
    1,126
    Matt, just went back and looked at your original pictures, since there is no posts actually bolted to the concrete, other than the first one, you would need to attach two horizontal members to your original railings, one high, one low, for proper support.
    I'd also like to compliment you on some very nice work, btw. Get the engineering squared away, you will be fine.
    Lodi, CA
    1,126
    Dammit, my scanner isn't cooperating, just looks at me with a bunch of blinking lights. Laughing at me. My thinking is, just to clarify, the new support posts go straight down to the first concrete attachment, then angle in to the vertical wall.
    Jul 2006
    1,508
    I didn't read every word of every post in this thread, so sorry if this was already mentioned. Why not weld a couple gussets in place?
    If this doesn't work please excuse the poor effort, my granddaughter just switched operating systems on this computer, and I'm lost without windows!
    Caution!
    Lodi, CA
    1,126
    To be honest, Sonora, the angled uprights still look too flimsy.
    What would it take, to get your grand-daughter, down here to Lodi, CA, to fix my scanner????????
    Jul 2006
    1,508
    Yeah those uprights are just a killer, too thin of material from the start.
    Wonder about taking the gusset up further? Probably look like crap tho!
    Caution!
