I definitely get it on the triangles, that's why I was thinking of a gusset on the weld tab. What i'm seeing is the flex is not in the diagonal but in the weld tab itself.
Any thoughts on pre-loading the railing? In other words, breaking the welds on the top of the outriggers, pulling the rail an inch or two out of plumb, then welding them back.
I'm also thinking of breaking the welds on the weld tabs and puliing them in closer to the wall so they exert less leverage on the weld tabs.
Results 11 to 20 of 24
Thread: Railing - need a little help
04-22-2010, 12:12 PM #11
Member
- Jan 2010
- Brooklyn, NY
- 73
"A little bit of knowledge is a dangerous thing"
Millermatic 135
Milwaukee 14" Dry Cut Saw
Milwaukee Deep Cut Band
Fully charged fire extinguisher
04-22-2010, 12:35 PM #12
- Oct 2007
- 2,949
NYS Stair and Handrail Codes
Matt: Do a Google search www.inspectapedia.com for NYS Stair and Handrail Codes.
You could fiddle around, doing this and that, and it still not be right. When it's built to Code Standards, there's no question as to it's strength and uniformity."Bonne journe'e mes amis"
04-22-2010, 12:38 PM #13
- Sep 2005
- WY...armpit of U.S.A.
- 636
Cut your losses on the angled uprights and go with straight upright standoffs that won't allow flex.
Miller DialArc 250
Lincoln PrecisionTig 275
Hypertherm 900 plasma cutter
Jet 14 X 40 lathe...ditto
Logan 7" shaper
Ellis 3000 band saw
Lots of dust bunnies
04-22-2010, 02:10 PM #14
- Feb 2009
- Lodi, CA
- 1,126
Do what Roy suggested, but set it off a foot or so, cut and angle the vertical tube down to the lower mounting point (against the side of the concrete). Like he said, vertical tube should be the same size as the first post, bolted at ground level. Use square tube for the offsets, doesn't matter what size, 1" would be appropriate, whatever looks good. Bring the vertical members a foot or two higher than the railing, mount lights on top, wired into your porch light. Use 12v lawn lights if you're worried about shock hazard.
This would look like it has a purpose, other than holding up the railing, and you can very discretely bring the wires up thru the vertical members.
I'd make a picture, but I can't do autocad as good as Roy
04-22-2010, 02:13 PM #15
Member
- Jan 2010
- Brooklyn, NY
- 73
The light bulb just went on...
Millermatic 135
04-22-2010, 02:21 PM #16
- Feb 2009
- Lodi, CA
- 1,126
Matt, just went back and looked at your original pictures, since there is no posts actually bolted to the concrete, other than the first one, you would need to attach two horizontal members to your original railings, one high, one low, for proper support.
I'd also like to compliment you on some very nice work, btw. Get the engineering squared away, you will be fine.
04-22-2010, 02:38 PM #17
- Feb 2009
- Lodi, CA
- 1,126
Dammit, my scanner isn't cooperating, just looks at me with a bunch of blinking lights. Laughing at me.
My thinking is, just to clarify, the new support posts go straight down to the first concrete attachment, then angle in to the vertical wall.
04-22-2010, 03:43 PM #18
I didn't read every word of every post in this thread, so sorry if this was already mentioned
. Why not weld a couple gussets in place?
If this doesn't work please excuse the poor effort, my granddaughter just switched operating systems on this computer, and I'm lost without windows!
Caution!
These are "my" views based only on “my” experiences in “my” little bitty world.
04-22-2010, 03:59 PM #19
- Feb 2009
- Lodi, CA
- 1,126
To be honest, Sonora, the angled uprights still look too flimsy.
What would it take, to get your grand-daughter, down here to Lodi, CA, to fix my scanner????????
04-22-2010, 04:13 PM #20
