Results 1 to 8 of 8
    Jul 2009
    Australia
    1,031
    Default Fork Dampener Rod Wrench
    I had to rebuild a set of Yamaha YZ125 H 1981 forks today. But first I had to make a T bar wrench to aid torquing up the dampener rod bolt.
    I had some 8mm mild steel rod for the job and a nut that would fit into the dampener rod end.
    The top of the damener rod has a socket end as per the following image.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,031
    To notch the 8mm rod I placed it into my drill press and drilled it out until I reached 8mm.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,031
    This drilling thing notched the rod well enough to fit it up just nice.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,031
    I positioned the rods together using a welding magnet and tack it using TIG.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,031
    I then continuously TIG welded up the T bar.
    The dampener rod bolt has to be tightened up to 35N/m so I tested it to 45N/m, no problems.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,031
    I then lathed up an insert and pressed it into the nut with a 20 ton press. It all fitted up beautifully.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,031
    I continuously TIG welded up the nut assembly.
    I used a Lanthanated electrode today just to see how they work, pretty good it carried the current fine.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,031
    When the new T bar wrench cooled down it worked great and the forks are already back in the bike ready to race tomorrow.
    Ji
    Grip it and Rip it
