    arkansas
    781
    Default The Legend AEAD 200 LE......parts
    I been tryin to revive an oldie but wonderful welder. the legend 200.... i cant find the throttle parts. i see pictures in the manuals, but no actual part numbers. i went to an onan dealer and they giggled a little. back to the LWS and still to no avail to find the parts needed... an idea or advice please?
    welder_one
    www.sicfabrications.com
    Dec 2009
    Midwest
    581
    Quote Originally Posted by welder_one View Post
    Member OnanParts is the guy you want to talk to.
    http://www.onanparts.com/
    TJ's a real good guy & has just about any part &/or information for any Onan engine you may have.
    Good luck.
    So you're telling me...You're not nostalgic? Then, give me another word for it......
    8,262
    Extremely unlikely your going to find any new parts for your machine, perhaps once in a while on fleabay.
    Best to look at the parts breakdown and build your own matching part from jobber materials.
    Dec 2009
    Midwest
    581
    Oh, Larry Burross prolly has what you want too.
    He's got more machines on his property than you can believe. If you can't make it, he'll most likely have it.
    weldersales is his member ID here & on welding web.
    Aug 2008
    Orange, TX
    1,216
    What 7A749 said. TJ (onanparts.com) is the man to contact for Onan parts. He can fix you up with an engine service and parts manual and most likely just about any Onan part(s) you may need - new or used.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    arkansas
    781
    thanks guys, i ended up going to an electric motor repair place and he had an old onan 18 on his yard, i took pics and measurements, went to the hardware store and bought the stuff to make the linkage. cost me 1.23 to make the stuff... thanks again, and she runs now, great running machine actually
    welder_one
