    Aug 2008
    Thetford VT
    64
    Default Worn out Equipment
    Thought I'd post a few pic. Worn out backhoe piviot.
    I'll post more with progress.
    Chad
    Trailblazer 302
    Suitcase 12 RC
    S22P-12 Feeder
    HF-251-2
    Spoolmatic 30A
    Maxstar 200 DX
    Shopmaster 300
    S-22A Feeder
    Coolmate 3
    Trailblazer 250G
    Apr 2010
    Newport News, VA/Fremont, OH
    182
    Yeah, I'd say that's worn out, has it seen grease since the factory did it?
    Dec 2009
    722
    He went a little far with
    Dec 2009
    722
    Looks like a good line boring job. tight area for the line boring machine to be.
    Keep us posted
    Aug 2008
    Thetford VT
    64
    Default Repaired
    Heres a couple of the repair. Customer claims he greases it often, not sure what often is to him.
    Chad
    Trailblazer 302
    Suitcase 12 RC
    S22P-12 Feeder
    HF-251-2
    Spoolmatic 30A
    Maxstar 200 DX
    Shopmaster 300
    S-22A Feeder
    Coolmate 3
    Trailblazer 250G
    4,486
    Yes, I know how people are, "was it making noise"? Oh no, just fell apart. Just started it yesterday. Ball joint fell off, rotor ground off till the puck come out of the caliper, wheel fell off in the driveway. But it just happened.
    You work on it? Oh no, not me, wires are on back wards and the screws laying there but I didn't touch it.
    You been greasing this,, sure,, all the time. OK, like once a day? Well,,, maybe not that much but all the time though,
    May 2008
    Mpls, MN
    464
    So how did you repair it, did you weld up all the missing material or cut the tab off and weld on new ones?
    -Dan
    Owner
    DW Metalworks LLC
    Miller Trailblazer 302
    Miller 8RC Feeder
    Miller Passport Plus
    Miller Dynasty 200 DX W/Coolmate 1
    Hobart Handler 135
    Hypertherm PowerMAX 30
    Smith O/A Torch Set
    Plus more tools then my wife will ever know about....
    Feb 2010
    Houston, Tx.
    378
    Brings back memories as I was a heavy equipment technician for a while. There was a company that made a G.M.A.W. machine that you set up on top of the worn hole and set your thickness then it welded the bore. It looked pretty cool, but I never got to try one in person. Don't you love it when you need a print to fiqure out the location of the original bore?
    Aug 2008
    Thetford VT
    64
    Talking
    Dan,
    I ended up cutting it off and repalcing it with a new one.
    davinci2010,
    I have a company close buy that I can rent bore welding and boring equipment that I yse on bigger projects but couldn't justify the cost for this job.
    Thanks all for the comments.
    Chad
    Trailblazer 302
    Suitcase 12 RC
    S22P-12 Feeder
    HF-251-2
    Spoolmatic 30A
    Maxstar 200 DX
    Shopmaster 300
    S-22A Feeder
    Coolmate 3
    Trailblazer 250G
