Im new to the forum so Im not sure if there is already a thread for this a quick search did not show anything.
In my spare time I maintain locomotives for a non profit and fabricating custom tools is a large part of keeping our equipment in service. Miller welding machines keep us going.
One such project is a customized crane used to lift the heavy cylinders of the locomotive on and off the locomotive itself.
Even a large scale valve spring compressor
Results 1 to 10 of 14
04-12-2010, 03:46 PM #1
Some Projects made with Miller Welders
Miller AEAD-200LE
Miller The Legend AEAD-200LE
Miller Spectrum 375 EX-TREME
Miller Diversion 165
Miller Maxstar 150S
Millermatic 211
Systematics 325 (It's Blue so it counts)
04-12-2010, 04:53 PM #2
Nice work there on the real trains...Bob
04-12-2010, 05:59 PM #3
04-12-2010, 06:11 PM #4
Thanks, with our most recent project I found myself faced with a major lack of tools. Since all these tools are very specialized they are very costly to purchase. So I came up with my own variation on them to get the job done. This included custom Jacking tools and anchor tools.
This is a tool used to Jack the Cylinder Heads free of the liners
While the head is being jacked free the Liner needs to be properly Anchored to make sure it does not lift out of its seat so a Anchor tool had to be Fabricated to make sure the Cylinder Liner did not come out with the Cylinder Head.
Miller AEAD-200LE
Miller Maxstar 150S
Millermatic 211
04-12-2010, 07:45 PM #5
- Sep 2005
- WY...armpit of U.S.A.
- 636
I'll stick with the MACs...
Miller DialArc 250
Lincoln PrecisionTig 275
Hypertherm 900 plasma cutter
Jet 14 X 40 lathe...ditto
Logan 7" shaper
Ellis 3000 band saw
Lots of dust bunnies
04-12-2010, 08:05 PM #6
A large majority of the tools I have made will work for the 645 or 710 blocks found in later model EMD power. Even though they were built for the 567 series.
One of the newer ones a Cylinder Head rotating tool. This was made cause the Heads weigh over 100lbs and can be a bit cumbersome to manhandle.
Miller AEAD-200LE
Miller Maxstar 150S
Millermatic 211
04-12-2010, 08:28 PM #7
- Feb 2009
- Lodi, CA
- 1,126
Tooling17039, any of those locomotives have "ROY WAS HERE" painted on them anywhere???
04-12-2010, 08:37 PM #8
I haven't found that on anything, all of our 12 locomotives started out life as Reading Company Locomotives and most went to Conrail after the merger in 1976.
One of our recent restorations
This is the Rear corner of the Cab we had allot of framework and structural repairs on this project
Everything Cut out
and the new framework
Miller AEAD-200LE
Miller Maxstar 150S
Millermatic 211
04-12-2010, 08:44 PM #9
- Feb 2009
- Lodi, CA
- 1,126
Well, Tooling, looks like some pretty clever tools you built, to do the work with.
Question, does the non-profit organization have a website?Obviously, I'm just a hack-artist, you shouldn't be listening to anything I say .....
04-12-2010, 08:47 PM #10
- Sep 2005
- 636
JSFAB, We don't run Geeps...SDs or nothing!
EDIT: Banged around on SD9s at the start, saw SD40s come and go along with the SD45s. Nowadays its either SD70MACs or rattletrap GE Evos.Last edited by WyoRoy; 04-12-2010 at 08:49 PM.
Miller DialArc 250
Logan 7" shaper
Ellis 3000 band saw
