Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Apr 2010
    Lethbridge, AB, Canada
    32
    Here are a few more of my cars:
    My car.
    Start:
    Finish
    I also own this 242.
    Started here:
    Synchrowave 180SD
    Millermatic 252
    Hypertherm 35
    MetalMaster 14" Saw
    Other random stuff.
    Jan 2010
    Calgary, Alberta
    197
    Thumbs up
    Thanks for the tips. I haven't done a whole lot on it recently... been trying to organize the garage to get the most workspace and best setup,etc.
    Appreciate the help!
    Jan 2010
    Calgary, Alberta
    197
    Default Gettin to work
    I'm beginning to work on the floor again. I'm wondering what different options there are for creating new floor pans.
    Any ideas would be great.
    I already have an idea from Coburn Perfomance which i am planning on but any pics from anyone to help me get the idea is great. This is to bend the ribs in it over some angle.
    Thanks in advance.
  4. #14
    Sep 2013
    1
    Thumbs up How to weld a car floor panel
    Quote Originally Posted by Sammy View Post
    Its a Volvo P1800. Not too many up my way. I have wondered about it though.
    Hi Sammy ....... If you require floorpans for your P1800, contact Olof at " Vintage Import Parts" located in Vancouver.
    I'm currently doing a resto on my PV544 and rec'd. excellent quality panels shipped to Winnipeg.
    Volvo PV544
  5. #15
    Aug 2007
    Northern California
    184
    I have another question. What guage sheet metal should i use? Is there any where that sells ribbed steel like an original floor pan?? I am on a tight budget right now so i don't want to be ordering $100 REPLACEMENT pans which i will have to cut anyway. Sorry i keep asking questions and no showing of the actual work. My camera is getting fixed righ now but when its back i will show pics.
    Thanks in advance for any input.
    Pictures are great as well.
    The ribs in the new sheet metal can be made with a tool called a bead roller. If you only need it for one job, it would be too costly to buy one. Any sheet metal shop could run a few beads for you.
    I bought a bead roller a while back and it's amazing how easy they are to operate and what a neat job they do.
    For pictures, go to Google Images and use keywords, "Bead roller floor pans". You will see hundreds of pictures and examples of how they operate.
    Good luck.
    Miller Syncrowave 200
    Milermatic 252
    Lincoln AC/DC "Tombstone"
  6. #16
    Mar 2011
    8
    I have actually had good results butt welding floor panels. It is a lot of work but the end result is great when you can't even tell that a floor was ever done on a car. I am no body guy but in working at a speed shop building hot rods I have came across a few cars that needed floors done. One thing that is worth its weight in gold is a spot weld drill bit! It saves a lot of work in peeling the old floor off of the floor supports and doesn't leave unneeded holes like a regular drill bit would.
    As for welding it, I have never had much luck running beads. I find it a lot easier and less risk of burn through/warping when just doing a bunch of start/stop tacks in one place then moving to another corner. Use a body hammer to work the metal into place as you weld to get the edges lined up nice.
    I have a picture of an old floor cut out and a new floor fitted on a 67 camaro I did like this but I am having trouble finding the finished pic. I will try to dig it up, but you couldn't tell a floor was done until you looked at it REALLY close and that was before high build primer and paint. I have never tried that hammer/dolly the welds trick mainly because it was always just me doing the work but it sounds like an awesome idea if you have two people. God knows I would have saved a ton of time, consumables and clean up from metal dust doing that instead of grinding the welds flush.
  7. #17
    Mar 2011
    8
    Another thing that helps is heat, weight and burn proof shoes (j/k...sort of) for pushing the new floor down and making it contour correctly to the floor supports. I melted my shoes quite a bit stepping down on a floor I heated with a torch to push down and meet the floor support to spot weld it. Almost considered welding up sheet metal toe pieces lol
