Not bad looks good from my views.
Results 31 to 40 of 62
04-19-2010, 06:16 PM #31
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
S-32 FEEDER W/1260 IRONMATE FC/GUN
HT/PWR-MAX1250 PLASMA
04-19-2010, 06:53 PM #32
- Dec 2009
- Williams Lake, British Columbia
- 718
Thank you.
04-19-2010, 08:42 PM #33
- Jan 2007
- 194
The reason I question this is it is alot harder to bend a flat bar on edge than it is to bend one laying flat. In rolling bending terminology it is refered to as hard way or easy way. Take a 4' piece of 1/4"x 1", you can bend it the flat way with your hands, try that on edge-no way. Please dont think Im trying to prove anyone wrong, its just that I have rolled and bent tons of steel, and made lots of fish plates for booms, trailers,LVL beams and they have all been stressed the "hard way".
04-20-2010, 07:12 AM #34
- Jan 2008
- So. Cal
- 100
Daniel, what is that blue stand? Is it an electric box? Thanks
Fab Tech
04-20-2010, 07:49 AM #35
- Dec 2009
- 718
Yes, It's got a long extension cord and a heavy base.
04-20-2010, 08:53 AM #36
- Jan 2008
- So. Cal
- 100
I’m trying to come up with a portable extension cord rack, your stands a great idea, nice height
Fab Tech
04-20-2010, 09:35 AM #37
- Feb 2009
- Lodi, CA
- 1,126
True, Eric, but think of an I-beam or an H-beam. Normally, the heaviest parts are the top and bottom flanges, with the web being half or less the thickness. An engineered structure, such as a box beam on an excavator arm, is the same. Adding additional metal, will do the most good, with the least amount of metal, if you put it closest to the maximum stress, which is normally at the top and bottom.
04-20-2010, 10:07 AM #38
04-20-2010, 10:18 AM #39
For a specific example . . . consider a piece of 1/4 x 3/4. True, it's almost 9 times as hard to bend it the "hard way" as the "easy way". Now plate it on both sides . . . you have a piece 3/4 square. Plate it top and bottom and you have an I beam 3/4 wide and 1-1/4 tall.
Compared to a piece of 3/4 square, the I beam is 2.4 times as hard to bend (assuming a vertical load and vertical web).
Dynasty 300DX
MM350P
Hobart Handler 120
Smith LW7, MW1, AW1
Smith AR/He Mixer
04-20-2010, 04:32 PM #40
- Feb 2007
- Near Dallas, TX
- 214
Dynasty200DX w/coolmate1
MM210
MM Vintage
Lincoln AC225
Victor O/A, Smith AW1A
Cutmaster 81
IR 2475N7.5FP
Evolution Rage3
Jancy USA101
9" South Bend
AEAD-200LE
