Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 62
  1. #31
    Apr 2006
    TAXACHUSSETTS
    1,412
    Not bad looks good from my views.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    S-32 FEEDER W/1260 IRONMATE FC/GUN
    HT/PWR-MAX1250 PLASMA
  2. #32
    Dec 2009
    718
    Thank you.
  3. #33
    Jan 2007
    194
    Quote Originally Posted by Portable Welder View Post
    Eric Carroll, The answer is yes.
    Strengthening the top and bottom flange of the boom is stronger than reinforcing the sides, unless your trying to reinforce the boom to increase its capacity on a side swing.
    Its not that fish plating the sides would'nt offer any added strength because it would.
    But Lb. for Lb. you get more strength for the same amount of material used when adding it to the top and bottom.
    The reason I question this is it is alot harder to bend a flat bar on edge than it is to bend one laying flat. In rolling bending terminology it is refered to as hard way or easy way. Take a 4' piece of 1/4"x 1", you can bend it the flat way with your hands, try that on edge-no way. Please dont think Im trying to prove anyone wrong, its just that I have rolled and bent tons of steel, and made lots of fish plates for booms, trailers,LVL beams and they have all been stressed the "hard way".
  4. #34
    Jan 2008
    So. Cal
    100
    Daniel, what is that blue stand? Is it an electric box? Thanks
    Fab Tech
  5. #35
    Dec 2009
    718
    Yes, It's got a long extension cord and a heavy base.
  6. #36
    Jan 2008
    So. Cal
    100
    I’m trying to come up with a portable extension cord rack, your stands a great idea, nice height
    Fab Tech
  7. #37
    Feb 2009
    Lodi, CA
    1,126
    Quote Originally Posted by Eric Carroll View Post
    True, Eric, but think of an I-beam or an H-beam. Normally, the heaviest parts are the top and bottom flanges, with the web being half or less the thickness. An engineered structure, such as a box beam on an excavator arm, is the same. Adding additional metal, will do the most good, with the least amount of metal, if you put it closest to the maximum stress, which is normally at the top and bottom.
  8. #38
    Jul 2006
    1,508
    Yes sir. Look at any load chart. Compare an S-shape to a W-shape, M-shape, or HP-shape. S-shapes come in a very distance 4th place! It is all about the flange.
    Caution!
    These are "my" views based only on “my” experiences in “my” little bitty world.
  9. #39
    Jan 2009
    SW Ohio
    131
    For a specific example . . . consider a piece of 1/4 x 3/4. True, it's almost 9 times as hard to bend it the "hard way" as the "easy way". Now plate it on both sides . . . you have a piece 3/4 square. Plate it top and bottom and you have an I beam 3/4 wide and 1-1/4 tall.
    Compared to a piece of 3/4 square, the I beam is 2.4 times as hard to bend (assuming a vertical load and vertical web).
    Dynasty 300DX
    MM350P
    Hobart Handler 120
    Smith LW7, MW1, AW1
    Smith AR/He Mixer
  10. #40
    Feb 2007
    Near Dallas, TX
    214
    The way I think of it is the metal farther away from the neutral axis (center of bend) has more leverage to resist bending. Putting more material on the flange is only good up to a point. When you start crushing and wrinkling the web, the flanges quit working.
    Dynasty200DX w/coolmate1
    MM210
    MM Vintage
    Lincoln AC225
    Victor O/A, Smith AW1A
    Cutmaster 81
    IR 2475N7.5FP
    Evolution Rage3
    Jancy USA101
    9" South Bend
    AEAD-200LE
