My job is to break it so that we have an excuse for having a welder on the payroll...
I'd fire my operator for being hard on my loader digging out those trees the other day ...but i am him
And i need to can my welder for taking too long to weld the hooks on the bucket ....but i am him
The only one that got anything done was the mechanic he only took 10 min to install the new seat.... dam that's me too![]()
Results 21 to 30 of 62
04-11-2010, 11:18 AM #21
My Job
Backed my CATMA over your CARMA
OOP"S clumsy me
What would SATAN do ??
Miller Digital Elite (new)
Jackson EQC master (old)
Miller Trail Blazer 302 Air Pak
Spectrum 625 Extreme
Suitcase 12RC
Evolution Rage 3 saw
Craftsmen Atlas 12X36 Lathe
Half a ton of tooling
Rusty old truck
04-11-2010, 11:56 AM #22
- Dec 2009
- Williams Lake, British Columbia
- 718
You should probably quit your job because your boss doesn't pay you enough ...but wait you're him
04-11-2010, 12:54 PM #23
04-11-2010, 01:57 PM #24
- Dec 2009
- 718
Sometimes I wish I'd be him though
04-11-2010, 04:48 PM #25
- Jan 2007
- 194
04-12-2010, 08:42 AM #26
04-12-2010, 09:54 AM #27
04-13-2010, 05:18 PM #28
fish paltes top and bottom...
wow! that looks like a fun project.
i'm absolutely no expert but it seems to me too like the fish plates on top and bottom would make a stronger repair...looks like they would keep the seams from "stretching" apart when the cylinder applies the force.
i look forward to seeing more pictures!
sometimes i wish i could quit my "real job" and do that kind of stuff, but i kind of like the climate controlled environment of the hospital!1 BEST 6 Y/O HELPER IN THE WORLD
2 VICTOR O/A TORCHES
LINCOLN SP 175 PLUS
4 EACH 20 TON JACKS
SEVERAL LESSER TON JACKS
SEVERAL GRINDERS
LOTS OF HAMMERS MISC SIZES
BIG PILE OF MISC TOOLS
CLASS A CDL'S
C7500 FLAT BED
4 TRAILERS
HOME MADE GANTRY CRANE
SOME GOOD COMMON SENSE (I THINK
TRACTOR WITH NEW HEAVY DUTY LIFT POLE -- FIND MY THREAD
6 GOATS, 1 DOG, 1 DONKEY...
ON AND ON AND ON...
04-13-2010, 07:02 PM #29
- Dec 2009
- 718
After talking about it for a bit with the owner, every joint made on the boom has a backing strip, every joint are welded right thru with a full penetration all the way in the backing. It will make everything sound solid.
So all this done will make the almost as strong as it was when it was new.
Then after I going to put a fishplate on the top and it will go cover both joint, I will put a fishplate on both side of the boom, these ones will extend pass both joints about 12 inches with a bunch of plug welds on them.
These will make the boom stronger then new.
I'll post some picks tomorrow after work, today it was going around with the root passes and adding backing on the edges where the top and bottom plates extend pass the side plate,
Still have more passes to go before fishplating
04-19-2010, 05:14 PM #30
Eric Carroll, The answer is yes.
Strengthening the top and bottom flange of the boom is stronger than reinforcing the sides, unless your trying to reinforce the boom to increase its capacity on a side swing.
Its not that fish plating the sides would'nt offer any added strength because it would.
But Lb. for Lb. you get more strength for the same amount of material used when adding it to the top and bottom.
