Results 1 to 10 of 15
    Mar 2006
    Hollywood, Florida
    10
    Question Milermatic 135 question
    I am begining to build an enclosed ATV trailer and I have a Milermatic 135 and use with flux core wire (too windy and no garage). Some people are telling me the 135 is not strong enough to weld 3/16 channel and angle. Any thoughts? I am having the tongue welded at a trailer shop that has a monster mig welder so I am not worried about that part.
    My Day Begins....When Your Day Ends
    The 135 should be fine for 3/16 with flux-core. Ive welded up to 1/4 with it. Now that i have a 251 i can see how limited the 135 was though. And for the coupler, just bolt it on.
    Nov 2005
    michigan
    47
    3/16 i think would be pushing the limits of that machine my opionion!!!! you could tapper the edges and making two passes
    miller 330 a/pb tig miller 175 mig
    student and hobbiest
    I welded some racks that were 1/4'' mild steel with a 75/25 mix with my 135 (single pass) and the racks are holding 3 tonnes each. I did taper the channel though before i welded it.
    Mar 2006
    Hollywood, Florida
    10
    Quote Originally Posted by kelly'$mygirl
    Thanks for the response! The heavy welds will be done at the trailer shop.
    Oct 2005
    Bulverde, Tx
    1,244
    3/16 with flux core is definitely within the limits of that machine. With proper care, 1/4 may be possible. I have done a lot of 3/16 with mine. Now anything over 1/8 with solid wire is definitely pushing it. It will give a cold 1/8" weld at best, but it will barely do it. If you have good single pass 1/4's, then you got very lucky since the recommended range (according to the Miller calculator) for 1/4" steel starts at 180 amps....way more than the 135 can put out.
    One key to getting good output with the 135's is the power input. They need to be on a dedicated circuit. If you must use an extension cord, use a heavy one and keep it as short as possible.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
    I have a 30 amp circuit just for my 135. Before when i ran it off a 15 amp circuit i was always tripping the breaker. It was spattering all the time and the welds seemed cold.
    Mar 2006
    Hollywood, Florida
    10
    Thanks again,
    We just took delivery of a Haulmark trailer at work. So I figured why buy plans when I have a full size model to work off. So I crawled under it to snap some pics to start the plans. WHAT A P.O.S. and we paid almost 10K for it. The frame is made with 2X6X1/8 rails (actually I think it's thiner than that) and 5x1/8 C channel. The welds look like a 4 year old did it. For strenght they welded to channels together in certain places.
    The trailer I am starting is a 18' x 7' toy hauler with living space. Rear ramp for loading the ATVs and a bunk area up front. 5200 watt generator and A/C (gets hot in South Florida). I will post pics during the process. Thanks again!
    Mar 2006
    Hollywood, Florida
    10
    P.S. I just talked work into buying a Miller plasma cutter....he he it's good to be the king.
    Lafayette, La
    319
    Quote Originally Posted by Rufridr069
    Thanks again, .......
    That's going to be pretty big project for MM 135. I'd get a bigger machine.
