Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Apr 2010
    12
    Default cracked frame Ninja zx6r
    i have a ninja that needs a crack welded an was wonderin if u guys would think it be a easy and safe fix i have a welder who is very good at welding aluminum but just wanted ur guys opinion thanks by the way the crack is right in middle where the factory weld is at and the other which i dont think is a crack is located same side on bottom which is the one that looks like a scratch or knife cut
    Apr 2010
    12
    Default ninja
    an by the way i got some heat with the other post in discussion about no pics and wheelies i have never done wheelies just recently bought this bike and actually never attempted a wheelie on none of my sportsbikes ive owned i just like the style, the ride, and the performance these bike produce
    Dec 2005
    wisconsin
    836
    Default As before
    As before in your other post, and especially after seeing this. You need to get ahold of kawasaki as get the specifics on the frame. I think if you just try to "weld up the cracks" your going to end up with a very questionable repair. I dont think you can go into this blind, you need to know what your working on. And as a side note, If it were mine and I repaired it, I would NEVER sell it nor even allow someone else to ride it. Just something to think about.
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
    Apr 2010
    12
    Default ninja
    i just don't get why it would crack at the factory weld like that wouldn't that be something kawasaki would replace, or be the factory's fault?
    Dman,
    You just bought this bike? I know for a fact my bike was totaled by the insurance company because my frame had a small dent. Wheelies generally cause cracks by the head tube from being slammed down too hard but that crack is up high on the main frame spur. Second hand or not if this bike has a clean title I'd contact Kawasaki.
    Just my 2 cents = That crack has to be from severe abuse or a wreck.
    I'll make no bad comments about a crotch rocket, because I'm getting the itch for another one myself. Too bad Honda has decided to make their bikes look like GSXR's.
    The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
    Apr 2010
    12
    what would i say to them
    Dec 2005
    wisconsin
    836
    Well your going to be more asking than saying The bike is 8 years old right, so the warranty is out. Safetly issue?? I dont think you could hold them accountable for anything as there is no recorded history of the machine, its use, abuse etc. At this point I would ask them:
    A) is this a common failure?
    B) Is there a factory repair method
    C) If not then ask, What is the base material, and what is the heat treatment after welding. Also ask what filler was used, as well as pre-heat temperatures.
    Now for liability reasons they may not tell you what the alloys are. You may get a more friendly response buy saying you want to build the motorcycle for racing and not street use.
    Miller Spot Welder
    Apr 2010
    12
    Default ninja
    i called kawasaki a little bit ago and they said they will replace the frame at no cost to me awsome
    Nov 2007
    Onalaska, WI
    145
    Quote Originally Posted by Dman2010 View Post
    WOW thats a man after my own heart!!!!
    If you don't ask you don't get.
    MM 211 W/ Spoolgun
    Diversion 180
    Spectrum 375 X-TREME
    Portable Victor O/A
    Palmgren Bench Drill Press
    14" Evolution Dry Saw
    IR 60 Gal. 3 HP Compressor
    Speedglas 9100x
    My Brain
    Jun 2006
    Maine
    732
    that's awesome!
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
