Results 1 to 10 of 10
    Default Tired of the old compressor taking my floor space
    I was tired of looking at this big thing on my floor so I elevated it. It is just basically a couple of brackets welded on the end of 3" x 4" rectangular tubing I had around. I put a 1 1/8" floor or it to minimize vibration. In addition I used some old scrounged shock absorber rubber parts to cushion it. I turned some special spacers on the lathe to get it the right height.
    The most time consuming part was the electrical wiring to it and the copper lines I am running in the shop.
    2,949
    Default "Lighter Than Air"
    Now that's innovative. If anyone asks how it got up there, tell 'em "it's making helium."
    "Bonne journe'e mes amis"
    I wish. Aren't Compressors the pits to handle.
    2,949
    Thumbs up
    Quote Originally Posted by modela View Post
    Like trying to grab a box full of bowling *****!
    I gotta say, that's creative. Looks like a "mezzanine" where you can work on the motor, or reach down and drain the moisture from the tank?
    The upstairs is a woodshop and you can reach over the balcony to work on it. On the bottom is a tube that connects to an automatic drain. I bought the compressor used, then had to replace the compressor head. I rebuilt the automatic drain yesterday. Now I will see if it works.
    Jim
    Nov 2007
    136
    On the bottom is a tube that connects to an automatic drain. I rebuilt the automatic drain yesterday. Now I will see if it works.Jim
    This auto drain? how does it work and how expensive to put together?
    MM 175 W/ Spoolgun
    Syncrowave 200
    Maxstar 200 dx (BROKE)
    Portable Victor O/A
    Palmgren Bench Drill Press
    14" Evolution Dry Saw
    IR 60 Gal. 3 HP Compressor
    Speedglas 9100x
    My Brain
    Wilkerson makes this one. It is available through Grainger or on Amazon.com. for about $100. I have another Wilkerson on my other compressor that has a float on it.
    Try: http://www.amazon.com/Wilkerson-X51-...2&sr=8-1-fkmr1
    I also heard that Harbor Freight has a cheapie but I don't know anything about it.
    Nov 2007
    136
    MM 175 W/ Spoolgun
    Syncrowave 200
    Portable Victor O/A
    Speedglas 9100x
    My Brain
    It works on pressure differential when cycling. See: http://www.paragoncode.com/shop/compressor/
    It looks like it is linked in with the unloader line where pressure is taken off when the pressure comes up.
    The Wilkerson only has an in and out. I am not sure exactly how it works. It was actually fairly complicated inside.
