Results 1 to 5 of 5
    Feb 2006
    B.C.
    22
    Default dodge 440 value?
    I have a ''78'' Dodge Powerwagon. Now parting out. any ideas as to the value of the 440 engine ? # on the block is 4006630-440-8 if that helps at all. it ran well when parked but has not ran for a few years.
    Feb 2009
    Maryland
    707
    The factory called late model blocks 'thin wall'. There is some evidence that this isn't true for the '76 and later blocks (those motors were used in trucks only as far as I can tell.) The blocks tend to be heavier - 230lbs bare vs. 210 or so for the old school thick wall blocks.
    See:
    http://www.arengineering.com/articles/sonicbig.html
    As for value, good 440 blocks are tough to find, but the market for them is thinning a bit. The factory of course makes new racing blocks (probably charging $3000 for them). I'd imagine the engine is worth a few hundred for the block. The rest would only be valuable as a replacement motor for another truck.
    To be sure, see if it has a forged or cast crankshaft (look at the parting line - thin == cast, thick == forged).
    Of bigger interest might be the other parts. Dana 60 rears? What about front? Big block 727 transmission with a transfer case?
    Con Fuse!
    Miller Dynasty 350
    Millermatic 350P
    -Spoolmatic 30A
    Hypertherm PowerMax 1000G3
    I know of 3-4 440 engines complete around Maryland for 300-450
    Feb 2009
    Maryland
    707
    Quote Originally Posted by Hemidude View Post
    With steel cranks or cast? I just may happen to have a '70 Barracuda in need of a race motor. (in Maryland)
    Con Fuse!
    Miller Dynasty 350
    Millermatic 350P
    -Spoolmatic 30A
    Quote Originally Posted by con_fuse9 View Post
    and how would anyone know without tearing them down?
