    Bend Oregon
    62
    Default Walking the cup, MIG and TIG...?
    I have seen walking the cup for tig welding. I would like to try it but i have a few questions first.
    -Do I need a grove or not, if so what kind?
    -Do I need a special kind of cup?
    -Do I need to fidget with my paremeters (ie. rod, tungsten, voltage, gas)?
    And I was watching this show on the discovery chanel, Howe & Howe Tech, and they where welding a fillet T joint on fairly thick steel (probaly 1/2 inch im guessing) with MIG. But what different was how he was welding, it looked like he was holding the shielding cup at the top with his left hand and rotating the handle in circles with his right hand. Does this have a name? How do I do it?
    Thanks!
    Miller Maxstar 150 STL
    Miller Millermatic Passport Plus
    Thermal Dynamics Dragun Plasma Cutter
    Protect your seccond ammendment rights! Join the NRA!
    Nov 2008
    Troy, OH near Dayton
    43
    Default root pass
    I watched a guy from Europe weld a pipe root pass with some metal-core(short circuit MIG transfer) a few weeks ago. He ran it using 1 hand, downhill, with the MIG gun nozzle riding the bevel. It was very similar to walking a TIG torch. Works good until spatter builds up to the point that the tip is shorted to the nozzle, at which point the nozzle welds itself to the joint....
    Quote Originally Posted by welder_guy View Post
    Thanks!
    Benson's Mobile Welding & Fabrication
    www.bensonmobilewelding.com
    Serving the Dayton, Cincinnati, and Columbus, OH metropolitan areas
    Bend Oregon
    62
    Quote Originally Posted by A_DAB_will_do View Post
    I might try that. But what i saw them do was use both hands and the torch did no make contact with the metal.
    146
    I've tried it on flat groove welds with FCAW.
    It's like the reverse of walking the cup you have to drag it. never tried it on the cap just for fill. Dont know if I'd do it on critical work - might get lack fusion depending on the groove profile.
    Bobcat 225
    The rest is bright RED "Tig & GMAW"
    Just got a new Hypertherm 30
    Nov 2008
    Colorado Springs
    276
    Default Mig Big
    I do alot of heavy plate with the Mig. 1/2" through 1-1/2"
    Spray, sheilded core and gasless
    If you are "SLAGING your DRAGING" is the rule around here.
    When we do these with reg MIG we push, backup and pause then push again.
    the slows the jack rabbits.
    Not such a good technic with flux or metal core because you can push or pull slag into the weld, so keep moving, pulling all the way.
    That's what works here, your shop may vary and probably does.
    Live Right Have Fun
    XMT350 CV/CC
    22A Feeder
    MM175
    TB302
    12vs Extreme
    Hypertherm PowerMax 1000
    20" x 40" CNC Mills (2)
    16" x 60" engine lathe
    65 Ton edwards iron worker
    3/16' x 24" power slip roll
    16' power feed mitering bandsaw
    and other fun toys
Tags for this Thread
