Results 1 to 10 of 20
    Apr 2009
    A State of Confusion
    143
    Arrow What is your most used manually operated Practical Home shop built tool/tools
    There have been a lot of useful ideas of home shop built tools and equipment on the site and I would like to see other ideas of other manually operated
    So if you have any home shop built tool/s that you use often? No matter how crude or rough in design it may be or how common.
    If so and you would be willing to share you design and photos of your tool you built plans, dimensions, materials tooling to build etc.
    Anything manual operated from yard tools to shop tools and specialty tool that served you well in the application you designed it for.
    Any devices for holding things at odd angels like weed eaters and chain saws for repair to screw jack type lift’s and Jig’s for line fabrication of any item or product.
    Thanks'
    CH!
    Feb 2007
    Spruce Grove, Alberta,Canada
    583
    A BROOM!! To sweep up your mistakes!!
    Sep 2007
    Medford MA
    524
    Workbench
    The home shop does not have as much room as I have tools and stuff --
    so a work bench with good storage, ability to serve multiple uses, be on
    wheels (to move it out of the way) is really necessary. Without it, I'd
    have too much space devoted to storing things and not enough to
    actually do anything.
    Frank
    Jan 2007
    Delmont, PA
    291
    Hey CH,
    Here's some of my homemade tools I use daily.
    1. Scroll bender
    2. Bracket bender
    3. Hydraulic press
    4. Sq. steel bender
    5. Rodbender
    Have some jigs & fixtures also. Another post....
    Denny
    Apr 2009
    Webster WI
    202
    Great job. Keep the photos and ideas coming. Love to see how inventive all of you guys are.
    Dynasty 350 - My New Baby
    Millermatic 210 Mig with Spoolmate 3035
    Miller Thunderbolt XL 225/150 AC/DC Stick Welder
    Miller Specturm 625 Plasma Cutter
    Speedglas 9100 auto dark helmet
    Jackson auto dark helmet
    18.5 CFM Eagle Compressor
    Oxy/Act
    Horizontal Band Saw
    Dewalt 14" Chop Saw
    7 1/2 Dewalt Angle Grinder
    4 - 4 1/2" Sears Angle Grinders
    1 - 4" Makita Angle Grinder
    2 - IR Die Grinders
    All of which my wife says will be a "he$$ of a garage sale"
    Jun 2006
    Alamogordo, NM
    45
    Default re: What is your most used manually operated Practical Home shop built tool/tools
    Quote Originally Posted by Leefy View Post
    I may have posted it before, but I still use these day in and day out. It's a copy of woodworkers hold down clamp. I just put it over a workpiece on my welding table, smack the tool once or twice with my brass hammer and the piece is usually secure enough to weld or grind on. I don't use them daily, just every time I'm using my welding table.
    Jan 2009
    Gold Hill, NC
    51
    Denny,you have some great ideas,thanks for sharing them on the board. Now if I can just get time to make some of them.
    I got a 4 foot 1\2" extension bar for when I took out my tranny. I got a dodge ram. I also made a little pully for the differential nut or bearing... it's been awhile.
    I'll get some pics up as soon as I can.
    -Tre
    Apr 2009
    143
    Quote Originally Posted by yorkiepap View Post
    Hey CH,
    1. Scroll bender
    2. Bracket bender
    3. Hydraulic press
    4. Sq. steel bender
    5. Rodbender
    Denny
    Always a pleasure to see your ideas Denny would like to see pic’s of the jigs when you get the chance.
    Keep them coming: cool:
    CH!
    Apr 2009
    143
    Quote Originally Posted by jworman View Post
    Great idea might have to make one or two for my welding table less adjusting of the C-clamps for quick securing of a work piece not a bad idea at all
    Keep them ideas coming!
    CH!
