Results 1 to 10 of 20
    Mar 2010
    South Dakota
    19
    Default trouble with bobcat225g and 8vs feeder
    Hello everyone....I was wondering if anyone out there uses a bobcat 225g with a wirefeeder. I have a 8vs and tried it on 3/16 plate but could not get any penitration...had it set to cv using .035 wire...should I try smaller wire? any sugestions would be apreciated..thank you
    Lodi, CA
    1,305
    Are you using the right polarity??? Remember, Reverse Polarity is electrode positive.
    That should do that job no problem.
    What are ALL of your machine settings.
    Ranges, CV or CC.
    Does the machine run up to high RPM?
    a-
    Mar 2010
    South Dakota
    19
    I have the process switched to negative for wirefeed...the amperage set all the way down where it says for wirefeed...the feeder is set to cv...and I'm using straight co2...the enigne revs up and welds fine when using stick...I will get a tach and see if the engine rpm's are running where it's supose to. thanks for the input I'll post what I find out.
    2,949
    Question
    What type of wire are you running? If you are using shielding gas (100% CO2), and solid or gas-shielded flux-core wire, the gun should be DC+ and the work clamp Neg (-).
    DC+ is "Reverse Polarity" (DCEP)
    DC- is "Straight Polarity" (DCEN)
    Also, make sure the switch inside the case of the 8VS is set to "CV" as well.
    In other words, the Positive lead from the welder should plug in to the lead on the feeder.
    The work clamp lead should be attached to the NEG lug on the welder, and the voltage sensing clamp from the feeder should be attached to your work as well, to complete the curcuit.
    "Bonne journe'e mes amis"
    Mar 2010
    South Dakota
    19
    did some more research and it seems like everyone says these are very cold blooded machines(the onan engines). it worked better after letting it run for probably a half hour. I didn't get a tach yet to check the rpm's on it. and since I did rebuild the engine it probably needs to be adjusted. picked it up last summer for $200 with a rod out. and just recently got the feeder off of ebay. I also tried it on cc, doesn't weld very smooth but ya get alot more heat. thanks for the helpful advice!!!
    2,949
    Question
    Quote Originally Posted by flatbroke View Post
    Doesn't sound like you've got things hooked up properly.
    There are 3 "lugs" on the front of the machine. Facing the machine, on the extreme left is the "work" lug (ground). The two on the right are for CC (Stick & TIG) and CV (wire feed)
    Earlier I asked what type of wire are you running? Whether it's solid MIG, or gas-shielded flux-cored wire, you should have the polarity selector set to "+"
    Hook the lead from the "CV" lug to your feeder. The machine's ground clamp, and the feeder's "ground" clamp should both be attached to your work.
    Set the machine to "CV" output, and adjust the voltage around 21-22 volts, and the WFS on your feeder to 320-340 IPM. There's a chart inside the lid of the feeder which gives operating parameters.
    I don't see a need to let the machine "heat up" for over 1/2 an hour to make it weld correctly. If it welds fine in CC mode (stick), it has to be a hook up issue with your feeder.
    Keep in mind, voltage drop has to be considered. Depending on your cable size and length, you may need to adjust your voltage higher (by a volt or 2) to compensate. If you find your wire "stubbing" out, increase the voltage. If you find that adjustment creating too much penetration, reduce voltage and WFS. You just have to "play" with it to get optimum performance.
    National City CA
    1,086
    I think Dave is right. Sounds like a connection issue.
    is the Voltage rage selector in the correct area for the voltage you need??
    South bend lathe 10LX40
    K.O. Lee surface grinder 6X18
    Auto shades are for rookies
    www.KLStottlemyer.com
    southern California
    1,783
    Dave, Trailblazers have 3 weld output lugs as you describe, however Bobcats have only 2 lugs, positive and negative. The process switch on the face of the machine has CV and CC positions, as well as Neg and Pos electrode positions. He can select CV (wire) NEG or POS on the selector switch, high or low output, and then use the fine dial to adjust it from there.
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    Aug 2008
    Orange, TX
    1,216
    Actually, the earlier Bobcats had 3 output studs too. I have a 225G 'parts' unit with the 3 studs and a three years newer 225G Plus working unit with only 2 and a CV setting on the process selector switch.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
Tags for this Thread
