    Jan 2010
    Brooklyn, NY
    73
    Default Nozzle and Flux-core
    Is the brass nozzle on my mig torch only necessary if I'm using gas? Do you guys ever remove it when using FC? I'm thinking I could get in to some corners a little easier without it, but I haven't actually tried it. Not sure if I'm missing something here.
    Also, my used MM135 came with an angled nozzle which I haven't tried. I'm not sure if it was an after-market purchase or came with the welder new. Would that be the way to go instead of removing the nozzle altogether?
    Matt.
    "A little bit of knowledge is a dangerous thing"
    Millermatic 135
    Milwaukee 14" Dry Cut Saw
    Milwaukee Deep Cut Band
    Fully charged fire extinguisher
    2,949
    Default Nozzle-less
    Matt: If you have an M-10 gun, you should use the gassless nozzle (#226190). It keeps all the spatter from going back down into your gas-diffuser and liner, and provides you with better visibility to maintain the proper CTWD (contact tip to work distance).
    CTWD is very important when FCAW. 5/8" is recommended for .035 wire. This "pre-heats" the wire prior to making contact with the work piece.
    Be sure and change the machine's polarity. DCEN is used for FCAW. The gun should be connected to the NEG (-) Terminal, and the work clamp to the POS (+) terminal.
    If you are using an M-25 gun, you'll have to convert it over to accept Bernard Q-300 consumables, and then purchase the NS-FLX FCAW nozzle kit.
    "Bonne journe'e mes amis"
    Jan 2010
    Brooklyn, NY
    73
    Thumbs up Thanks, Dave.
    That's just what I need. I'm using the M-10 gun. I didn't know there was a FC nozzle. Going to order one tonight,
    Millermatic 135
    Feb 2008
    896
    The FCAW nozzle also insulates the tip to prevent a direct short circuit to the workpiece in case you slip. This is not good for the machine.
