Results 21 to 30 of 36
Thread: Project ideas?
03-23-2010, 11:22 AM #21
- May 2009
- The Colorado Gas Patch
- 184
Steve
Bobcat 250EFI
Millermatic 350P
Hypertherm 1250
A Bunch of tools
And a forklift to move the heavy stuff with..
Looking at CNC Plasmas
It's Miller Time - Get Back To Work!
03-23-2010, 09:26 PM #22
No, i need to though. I havnt decided what exactly to do yet.. Im horrible at making decisions, and i hate doing it. But im kinda getting close to a final choice hah. And im not very good at blue prints with the bill of materials and all, so im kinda trying to put off doing that as well.. I procrastinate way too much.
Lala
03-24-2010, 12:17 PM #23
Member
- Jul 2009
- 62
Here's a few ideas that I do, mostly out of recycled metal:
-Get a section of chain, like a dog leash, and make a snake. For a "rattlesnake", use a bolt with loose nuts on the tail, and another welded to the top to keep them on. the tongue can be made from a fondue fork, and the head a serving spoon. I like using the dog leashes because the links are twisted, and give the snake more of a sinuous shape.
-Centipede: Use a bicycle chain, and weld bent nails to every other link (well, you want the centipede to bend, right?) Two more nails for antenna
-Ants: bolt for the body, six bent nails for the legs, two antenna. I also like putting a couple of nuts to either side for eyes.
-Spider: weld three large nuts in a row (if you can do bigger to smaller, even better!) Make legs out of nails - weld together at 90* - and then weld to the body of the spider. Don't make them all touch the ground, make it look like your spider is walking!
-Flowers can be plasma-cut from sheet metal, and then bent to shape. Tip: going to make a rose? Use barbed wire for the stem!
-Got a bucket of bolts? Make a skeletal hand, "Terminator" style. Weld the heads of four bolts together to form the "bones" on the back of the hand, then work on the "fingers." The "wrist" can be several rows of nuts welded together to the heads of the bolts. You can even make a stand to display this afterwards - I used a bicycle kickstand and a star lugnut wrench.
03-24-2010, 01:47 PM #24
i have a new 16in chainsaw chain, it doesn't fit my saw and i cant return it,,, any ideas into making that into something useful? lol
Anything you could do, I could do better.
I can do anything better than you!
Lockheed Martin
Armco Steel, Baltimore
USW local #3185
03-24-2010, 02:33 PM #25
Attatch a long cable to each end with handles on each end .......throw one end over a high branch to make a manual saw.
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
03-25-2010, 07:47 PM #26
Thanks spyguy :] those seem pretty cool, ill have to try the flower one out for sure, my step mom loves that kind of stuff for her back yard. Im actually making a sun for her back yard right now, i just started with the blue prints. After that ill be sure to make a few of those.
Lala
03-25-2010, 09:51 PM #27
It is amazing how we lose our creative side as we get older- even Young older like you
Give a child a Crayon and a Piece of paper- zero hesitation, instantly coloring, scribbling etc. and if yer not watching, coloring all over the d.a.m.n house
Give an adult a pencil and piece of paper..... instant Mental Block.
Procrastination- that's because yer afraid to Color
Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
03-26-2010, 07:21 PM #28
This is how it starts.
Then one day you walk through the door and Chris Hansen is sitting there!
Equipped with red and blue... and red and green!
03-27-2010, 07:35 AM #29
- Apr 2009
- A State of Confusion
- 143
Here is a t-post puller
Hello Kayla Welcome to the site
Here is a project that might be useful to make in welding class for a grade or what not, simple and easy to build and who knows it might even be a useful tool for someone you know.
http://www.millerwelds.com/resources...=T-post+puller
Let me know if you would like more info on material and measurements
CH!
03-31-2010, 01:57 PM #30
thanks crazy horse!
our budget is running too low to do projects right now, so im on hold for a while :/
were broke so no more metal, gas, or anything.Lala
