Results 1 to 3 of 3
    May 2009
    3
    Default Spoolmatic 30A Ext Cable Pinout
    I thought I have seen this before on here but I can't find it. I want to build an extension cable for my 30A spool gun. All I need is the pinout for the 14 pin connectors. Does anyone know which pins I need? I have the amphenol part numbers so I need to know is how many conductors my cable needs to be, what size would help and the connector pinout. Thanks
    Nov 2003
    3,690
    Jhara
    pinout is on page 28 of the PDF manual... 23 of the paper one
    here is the link
    http://www.millerwelds.com/om/o1213ae_mil.pdf
    hope this helps
    Heiti
    southern California
    1,783
    Your Spoolmatic extension cable will use a 10-pin connector, not a 14-pin. The 14-pin is for the WC24 controller to connect to the power source, if connecting the Spoolmatic to a power source with 24vac output but no 24vdc output (such as a Trailblazer or XMT).
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
Tags for this Thread
