Results 1 to 10 of 18
Thread: beer keg bbq
    Nov 2005
    michigan
    47
    Question beer keg bbq
    any one make a bbq from a 1/2 keg? i am trying to but as soon as i cut the side of it it srung open like an 1 1/2 out of round now i can't get it round the piece i cut out will not fill the hole the buttom is (was) convex now its all most flat tried hammering racket straps any advice thanks jason
    miller 330 a/pb tig miller 175 mig
    student and hobbiest
    Dec 2005
    Dallas, TX area
    267
    Default Wierd....
    How bout some pics?
    Triggerman
    Triggerman
    Ammonia refrigeration tech
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
    Nov 2005
    michigan
    47
    there is some pics
    S.W. Pennsylvania
    2,250
    You could try clamping strait edges to the cuts on both sides and that should return the rest to it original shape. then heat the whole thing with a rose bud to releive the stess and let it cool slowly.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
    7
    I have built many grills out of 55 gallon drums and the easiest way is to cut the drum completly in half then attach a lip around the top and bottom with 1 inch angle. this makes the grill a lot more sturdy and you dont have to line it up as exact as you do if you just cut out a section. if you dont use the angle your going to find the top is going to be really flimsy and theres going to be a gap.
    Feb 2006
    Oviedo Fl.
    26
    May be a dumb question but what about the toxins aluminiam gives off when you put flame to it.would'nt that contaminate the food?
    "Molten Metal Fusion Technician"
    Texas
    279
    Not anymore that other mat'l. that we use for pit construction which after completion we do a burn to "season" the pit. This looks like a SS keg.
    BTW, I have several Al. skillets that I use and I'm still kickin. Just my 2
    L*S
    Nov 2005
    michigan
    47
    these keg is stainless steel
    Jan 2006
    long sault ontario canada
    114
    Default barbqs
    I seen them on atv show last week made from a drum preeety simple too!Go to RED HOT AND READY with a search should take ya right in!
    smokin ana grinnin for 20 years
    Owner MARKS MOBILE WELDING
    trailblazer 302
    hobart suitcase mig
    miller 30a al spool gun
    laramy plastic welder
    brocco cutter
    pipe beveler
    all walter hand tools
    Feb 2006
    4
    all i have seen are stainless and they make a nice little bbq grill. just whack the top into with the plasma attach hinges then cut the rest of the lid out attach some legs and some expanded metal for the grill and away you go
