Hi guys, did anybody know certainly about what kind of eye protection is needed for Plasma Cut. Thanx
Results 1 to 8 of 8
Thread: plasma cut eye protetection
03-14-2010, 09:20 AM #1
- Mar 2010
- 2
03-14-2010, 09:51 AM #2
the manual that came with my Cutmaster 52 said to use a shade 8 filter.
Bobcat 225NT
Cutmaster 52
Lincoln Weld-Pak 100 buzz box
Caterpillar TH63
'07 Kawasaki ZZR600
03-14-2010, 09:59 AM #3
If you're going to cut a fair bit like that,Hypertherm makes a shield that is clear on the bottom and a #6 for the top half.This way,your whole face is protected from splash back,not just you eyes.And it makes it quick to go from cutting to grinding parts,no time waisted changing shields.You can also buy one that has #8 for the top.The $40 CDN i paid is cheap to protect all that prettyness
Frank
Millermatic 252
Millermatic 180
Hobart spoolmate 3035
Digital Elite
03-14-2010, 12:20 PM #4
- Jan 2010
- pennsylvania
- 10
If I'm only doing a few cuts at a time i wear shade 5 safety glasses. If I need to cut a lot I have the Hypertherm Face sheild. It sounds like the shield described above. Mine has a shade 6 and i believe you can get it with a shade 8. A AD welding hood works well if you can adjust the shade low enough.
mm251 w/ 30amp spool gun
diversion 165
mm140
Hypertherm powermax 45
03-15-2010, 04:51 PM #5
I use a Sellstrom full face shield it has a #8 flip up on the unit. If you need glasses to read or to see up close this is the way to go. I picked up mine on line from Sears#009-20685 just under $50 bucks to the door. ck out www.sellstrom.com for ther info.
03-15-2010, 05:29 PM #6
Here is the link to another thread on the subject
The hyperthrem and the Sellstrom unit are the same.
glen, If your not on the edge, your wasting space
03-15-2010, 10:28 PM #7
I have a Selstrom helmet but I also use my Harbor Freight auto darkening lid turned all the way down. It's a little dark at 9, but more comfortable on longer jobs and I'm not switching back and forth between headgear.
03-17-2010, 05:12 PM #8
- Feb 2007
- Near Dallas, TX
- 214
I just use the auto helmet. It a #3 shade when not activated, and a #8 at the lowest when activated. I try to keep my head positioned where the helmet doesn't get triggered. It's easier to see that way. The helmet protects from splatter well enough.
Dynasty200DX w/coolmate1
MM210
MM Vintage
Lincoln AC225
Victor O/A, Smith AW1A
Cutmaster 81
IR 2475N7.5FP
Evolution Rage3
Jancy USA101
9" South Bend
AEAD-200LE
