    Jan 2010
    pennsylvania
    10
    Default cutting angles in steel
    What do you guys use to accurately cut angles in steel? Especially angles over 45 deg.
    mm251 w/ 30amp spool gun
    diversion 165
    mm140
    Hypertherm powermax 45
    Apr 2008
    171
    swivel head band saw
    Mostly use a 9" angle especially when the angle or piece of steel is to large
    for the cut off saw. Use OA on heavy pieces.
    Quote Originally Posted by BC Iron works View Post
    what model saw is that?
    2,927
    Grizzly
    Maryland
    707
    Default cutting pre-bent tubing
    Sorry for the little bit of a hijack.
    I saw this:
    From these guys:
    http://www.icengineworks.com/icewmain.htm
    I don't have room right now for a big vertical band saw. Is there anything similar that can cut right along the radius of a tube? Keep in mind that I mostly get 180 degree j bends, and unless I'm cutting exact 90 degrees, I start running the risk of hitting the 'back leg' so to speak.
    For exhaust system you want to make sure you don't cheat the bend (at least in theory) so its nice to be able to cut right down the radius line. Honestly, if I eye ball it with chop saw its usually O.K. I just sometimes have to come at it from multiple directions to get it to cut all the way.
    Con Fuse!
    Miller Dynasty 350
    Millermatic 350P
    -Spoolmatic 30A
    Hypertherm PowerMax 1000G3
    Miller Multimatic 200 - awesome portable MIG (and stick and TIG)
    Miller Maxstar 200DX - portable TIG and stick
