Results 1 to 7 of 7
    Nov 2009
    7
    Default wirefeed welding travel speed
    Im doing a project for school and am trying to figure how much it would cost to make my project. I just need to know what you think is average wirfeed welding speed with .035 wire 250in/min @17.5 Volts
    8,351
    I'd guess your welding 14 gage material with C25. 030 wire would be a better choice.
    Still I don't get your question as your answer is in your question. hmmmmm
    Nov 2009
    7
    I guess I could have worded it a little better. But I have roughly 256 inches of weld. Now how long will that take me to weld? So what is the average travel speed of someone wire feed welding. I have never timed myself welding so im not sure, especially cause I get into a zone and lose track of time. So in terms of inches a minute how fast does the average guy go. This doesnt need to be exact I just need a rough estimate.
    8,351
    No one can answer that, wayyyy too many variables, like the material and thickness your welding, machine your using. If your weaving, running straight, or stitching, corners, butt welds, in a shop or outdoors. even down to the input power on the machine.
    Feb 2006
    Northern CA, Shasta CO.
    157
    2,971
    For a rough estimate
    http://www.millerwelds.com/resources...ur-skills/mig/
    Click on the Mig Welding Calculator in the Top right corner.
    Example for 1/8" Steel
    Wire Size & Wire Feed Speed:
    .035" (0.9 mm) at 280-300 ipm
    .045" (1.1 mm) at 140-150 ipm
    Shielding Gas & Voltage Range:
    CO2 21-22 Volts 75% Argon/25% CO2: 18-19 Volts
    2,971
    If you want better Weld Cost estimate click on Lesson 9
    http://www.esabna.com/EUWeb/AWTC/Lesson1_1.htm
