Results 1 to 10 of 15
    Jul 2008
    Delhi, Ontario:
    1,998
    Question Welding AR 400 Plate
    Does anyone have experience welding AR400 plate ?
    I have a job comming next week, I'll be welding a 4'x 6' AR 400 plate inside of a Large vat for mixing types of soil & fertlizer
    I haven't seen it yet , but from what they say it's quite a large Vat .
    So any insight from anyone that's done this before would be great !
    It's being Rolled this week , to be installed next week .
    .......... Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    Jul 2006
    1,508
    Norm right from Lincoln.
    AR400 is a quench and tempered steel and may be difficult to weld due its high strength and hardenability. The base steel around the weld rapidly heats and cools during welding, resulting in a heat affected zone (HAZ) with high hardness. Any hydrogen in the weld metal may diffuse into HAZ and may cause hydrogen embrittlement, resulting in delayed underbead or toe cracks outside of the weld. To minimize heat affected zone cracking:
    Use a low hydrogen consumable with an -H4 or -H2 designation.
    Preheat to slow the cooling rate. Note that excessive preheat may anneal the base material.
    Slow cool. More time at elevated temperatures allows the dissolved hydrogen to escape.
    Peen the weld beads to minimize residual weld stresses.
    Use the lowest strength filler metal meeting design requirements. If making fillet welds, the weld can be oversized to give the specified strength
    Minimize weld restraint.
    Caution!
    Jul 2008
    Delhi, Ontario:
    1,998
    Default AR 400 plate.
    Thanks Sonora;
    I was somewhat framiliar with what you stated above.
    So E- 7018- H4 would be the best rod to use, with mild pre-heat.
    I'm not sure how I could slow the cool down time?
    Peening , Yes !
    It's a fairly large piece of plate- 4'x6' rolled , I'm not sure of it's thickness.
    Do you think I should back - step my way around the perimiter ?
    .............. Norm
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
    Jul 2006
    1,508
    I back step everything!!!!!!!!!!!!!!!!!!!!!!!!!!
    Maybe rent one of these for the post heat?
    http://www.masterheaters.com/kero/
    Caution!
    Jul 2008
    Delhi, Ontario:
    1,998
    Default AR 400 plate .
    Sonora, No I don't think I'll use one of those heaters !
    It's a very confined space !
    I'll be inside a Vat welding a 4' x 6' plate , Hot and Smokey enough !!!!!!!!!!
    ............ Norm
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
    4,487
    I remember welding it down in conveyors, mild pre-heat and lo-hi. I dont think its a big deal.
    Jul 2006
    1,508
    Quote Originally Posted by nfinch86 View Post
    ............ Norm
    LOL!
    No I meant after you’re completely done. Aim the heather inside the vat, and let it cool with just this amount of heat.
    Caution!
    Jul 2006
    1,508
    That is all I ever done too. I was a little set back by how detailed Lincoln made it out to be. Guess I was lucky all those years!
    Caution!
    Jan 2008
    So. Cal
    100
    Nabed this from the hobartwelders
    http://www.hobartwelders.com/weldtal...ad.php?t=19493
    Fab Tech
    Jul 2008
    Delhi, Ontario:
    1,998
    Question AR 400 Plate
    Thanks, Fab Tech, Sonora & everyone else !!!!!!!!!
    I do have one of those propane heaters, but the darn thing will lite but Not stay lit .
    So I guess it will be E-7018- H4 or H2 , with mild pre- heat, back stepping around the perimeter, peening as I go !
    It's an inside job, so it should not cool too quickly, maybe cover it with a weld blanket .
    ............ Norm
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
