There's probably a better name for this than Entertainment stand. ?? I can make it - I just can't name it. Scott
Results 1 to 10 of 11
Thread: Entertainment stand
03-10-2010, 10:57 AM #1
- May 2007
- 19
Entertainment stand
03-10-2010, 12:55 PM #2
Nice job. Brings tiers to my eyes
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
03-10-2010, 03:02 PM #3
- Sep 2007
- Medford MA
- 525
03-10-2010, 03:03 PM #4
- Sep 2007
- Medford MA
- 525
03-10-2010, 03:04 PM #5
i'd go with Effin Sweet!! its a nice looking setup man. Well Done!
American By Birth, Union by Choice!
4th generation Pipefitters LU 537
SpeedGlass 9000x Hood
Miller Elite Titanium 9400 Hood
03-10-2010, 03:40 PM #6
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
03-10-2010, 07:54 PM #7
- Sep 2007
- Medford MA
- 525
03-10-2010, 08:36 PM #8
Nice work Scott, looks like a nice set up not having to see legs on the corners. A little different look from the normal stuff is always good.
Stickmate LX 235 AC / 160 DC.
Clarke 180 EN Just in case
Spectrum 375 X-Treme.
Milwaukee 14" Chop Saw.
4 x 6 Horizontal Band Saw.
Projects and Misc Albums
03-11-2010, 06:37 AM #9
- Apr 2009
- 143
very cool. i wish i new alittle bit about woodworking, maybe someday when i have a real shop of my own. Wood just adds another cool texture to steel projects. Here is a TV stand i built a while back.
03-11-2010, 12:12 PM #10
- Mar 2010
- west wales, great britain
- 3
hi-fi stand
that looks very nice. really neat and minimalist. if someone wants to copy this design or make something similar, but not use wood for the shelves, why not use marble slab cut too size. i'm sure you could get some cut too size in a kitchen fitters shop or even where they make headstones for graves.
these places always have off-cuts they cannot use for anything else, once their main job has been made. i have done this for all my hi-fi tables i have made over the years and found the shop people only too happy to offload their waste pieces of slab. they have even been happy to cut and polish these offcuts too my requirements, provided they have enough of the type i want.
i don't know what you would spend on marble over in your part of the world, but i have usually paid around £20-35 per square foot (depending on the quality) so a shelf of around 14"X18" could cost anything from around £35 up. using marble will also make the hi-fi sound better, due too the inherent damping effect it has on vibrations. something which wood does not normaly have a big effect on (for hi-fi anyway)
if you are a bit skeptical about the effect, try a bit of stone slab under the cd player first, but remember that marble is more dense and will work a little better (and look a lot better)
i have also found that molten lead in the frame works wonders, but you need to do this outside wearing a mask and goggles, NOT in the garage or other enclosed space. you WILL give yourself a headache otherwise (at least) or at worst, give yourself lead poisoning. the headache is just the first warning. so be carefull and plan what you are going to do properly.
i have made at least 8 tables this way (at last count) with no ill effects. but you can't be too carefull when using molten lead. anyone need advice, let me know.
