Making a sub frame brace. Wanted some feedback on my welds. Here is a sample.
http://i826.photobucket.com/albums/z...2/DSCN0701.jpg
Thread: tubing weld
03-08-2010, 09:10 PM #1
- Mar 2010
- 5
tubing weld
03-08-2010, 09:54 PM #2
Overall OK, two things jump out at me. One is some undercut, and the other is how small the reinforcement is. I assume you want this to hold together, in which case I would practice larger fillets, eliminate ALL undercut, work on fluid smooth consistent welding. If 4130 heavily consider tempering afterwards.
-Aaron"Better Metalworking Through Research"
Miller Dynasty 300DX
Miller Dynasty 200DX
Miller Spectrum 375 extreme
Miller Millermatic Passport
Miller Spot Welder
Motor-Guard stud welder
03-10-2010, 05:10 PM #3
- Mar 2010
- 5
So I should add a bit more filler then and build up the bead?
03-10-2010, 10:20 PM #4
Yes, and keep in consistent. Undercutting is a bad deal, and just one half scallop of undercut from "under dabbing" one dab can be a good place for a crack to start. Also think of it as not letting the puddle run away from the filler, keep the puddle well "filled" the whole time.
Miller Spot Welder
03-12-2010, 09:58 PM #5
- Mar 2010
- 5
Here is the mostly finnished piece. I have to trim the mounts and i am going to add a few gussets when I have some more free time. Thank you for your advice. I found that if I added some more filler in the beginning I didnt have to catch up to the bead, and I had more control over it.
03-13-2010, 07:50 AM #6
Miller Spot Welder
I know what you mean about having more control of the puddle. Another plus to having a larger weld fillet, is that it slows the cooling rate and gives you a better chance of not having a failure prone HAZ.
