Results 1 to 10 of 11
    Bend Oregon
    62
    Default Welding positions
    I know there is positions like 5G and F2 ect. That tells you the position and parent metal configurations. But my question is can it be welded with any kind of process?
    Miller Maxstar 150 STL
    Miller Millermatic Passport Plus
    Thermal Dynamics Dragun Plasma Cutter
    Protect your seccond ammendment rights! Join the NRA!
    Oklahoma
    730
    Smile
    Quote Originally Posted by welder_guy View Post
    The position designations you mention tell nothing about the parent metal.
    The position designations tell you,well, postions.
    Griff
    southern California
    1,783
    G = groove joint
    F = fillet joint
    R = with restricter plate (for pipe)
    1 = plate flat, or pipe laying down and rolling
    2 = plate horizontal, or pipe standing up
    3 = plate vertical
    4 = plate overhead
    5 = pipe, but i forget the position, i think laying down not rolling?
    6 = pipe at an angle, no rolling
    You can use just about any process in any position, except spray transfer mig, which is only useful in the flat and horizontal positions due to excessive puddle fluidity. Pulsed spray transfer mig can be used in all positions though, with the right settings.
    Not all stick electrodes are suitable for all positions. E7024 is for flat/horizontal only. The 3rd digit designates the position. 1 = all position, 2 = limited position.
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    Jun 2004
    nj
    204
    see: sperkoengineering.com/html/Position.ppt
    (from http://www.sperkoengineering.com/html/asme.htm)
    Feb 2010
    Cambridge, MA
    213
    Quote Originally Posted by Desertrider33 View Post
    G = groove joint
    F = fillet joint
    3 = plate vertical
    4 = plate overhead
    5G is a horizontal pipe, vertical weld, no roll.
    6G the angle is 45 degrees
    American By Birth, Union by Choice!
    4th generation Pipefitters LU 537
    SpeedGlass 9000x Hood
    Miller Elite Titanium 9400 Hood
    4,469
    Welding positions, on your back, sitting down, underneath, up on ladder.
    Sep 2009
    4
    Default pulsed spray
    G = groove joint
    F = fillet joint
    3 = plate vertical
    4 = plate overhead
    This is a little off topic. I have a mm 350p but I have never used pulse mode. How would you compare out of position welding in pulse vs short circuit? Much of the welding I do is repair so it can be in any position and on any condition iron 16ga up through 1/2 inch or heavier. I am using straight co2 and .035 or .045 70s-6 wire. Guess what I am really trying to decide is should I go to the trouble of getting some 85/15 or 90/10 gas for pulse. Straight co2 or 75/25 are easily available but that's about it unless I special order it and drive quite a ways to get it.
    Feb 2010
    Cambridge, MA
    213
    you forgot in a mud and water filled trench
    Lake of the Ozarks MO
    3,594
    Quote Originally Posted by roylowell View Post
    So your sales people managed to sell you the best machine they could but managed to drop the ball when it came to being able to even use it??
    Please don't take this as if I am being mean spirited but why did you buy the 350P in the first place ?? Pulse is what it is all about. Otherwise you should have got the plain jane MM350.
    To put it in real world terms....sure you can do just fine with just straight mig and turn out great work. We have done that forever. GMAW-P is just something that seems to me to be a bit easier to get better results with as far as clean spatter free work goes. I am thinking I find filling gaps easier as well.
    It is sorta like having a Dynasty instead of a Syncrowave. More buzzers and bells but in the end it is really how good of a machine operator you are. But that said a good operator can get better results from a better machine.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Sep 2009
    4
    I bought it on the internet. My son needed a welder so I gave him my mm250 and got a 350p because I wanted one. From what I've read it's supposed to be quit a welder. I've got an aluminum trailer so I'll probably get a push-pull gun and learn aluminum some day. I've read that spray transfer won't work out of position but I haven't found out much about pulse.
Tags for this Thread
