Page 1 of 6 123456 LastLast
Results 1 to 10 of 52
    Mar 2010
    22
    Default no amp control... econotig..
    hello all!
    i recently bought a used miller econotig.. and there is no amperage control at all via the foot pedal or hand control...
    i have the weld process switch set to gtaw... and the range/polarity switch set to dcen..
    i have a foot pedal as well as a hand control.. and neither of them are allowing me to change amperage.. they are more like an on/off switch.. weather i press the foot pedal a little or all the way it puts out the same (what i assume to be) 100% output
    the same goes for the hand control..
    basically the metal is over heating.. and glowing red hot.. with the arc jumping all over the place and burning holes through the material.. (from what i assume to be too much amperage)
    my welding scd10 ss pipe..
    this is my first time welding.. but i know im supposed to have control over the amperage.. not just an on off switch..
    local welding supply store wants 70 bucks just to look at the welder..
    online manual says to clean out the inside of the welder.. i may try this in a little bit.. but from what i see online this is a common problem with econotigs..
    http://dtsfab.com/index/index.php?topic=1829.0
    http://weldingweb.com/showthread.php?t=35789
    ^^ this guy apparently fixed his problem..
    im trying to contact the person i bought it from but i doubt ill get any help from him..
    thanks..
    jay
    Feb 2009
    146
    Default Amp Control
    Turn knob 4 to the left!
    Bobcat 225
    The rest is bright RED "Tig & GMAW"
    Just got a new Hypertherm 30
    Mar 2010
    22
    Quote Originally Posted by Hillbilly69 View Post
    i wish it were that easy!
    knob 4 is inactive in tig mode.. its only used for stick welder mode..
    well im hoping this is my only problem.. i dont see any scorch marks on the board but i wont be for sure till i start to clean out the welder..
    a simple air can will not clean this up.. can i use electronic parts cleaner to just spray the entire inside of the machine?
    electonic parts cleaner is like brake parts cleaner.. propably the same thing.. non conductive.. and i wont turn on the machine till im sure that its 100% dry.. maybe 2 cans of electronic parts cleaner then 1 can of air to make sure its 100% dry?
    Mar 2010
    22
    Mar 2010
    22
    Oct 2004
    Edmonton, Alberta
    6,763
    Your "D" pin appears to be missing on your amphenol, thus no control. Find it and shove it back in.
    Mar 2010
    22
    thanks for the reply!
    i just ran over and checked it out and there doesnt appear to be any missing pins from inside the welder..
    like this picture shows..
    all the wires are already connected and the one that goes under there is connected to something else..
    the bunched wires that lead to the pins are ziptied together so it doesnt look like there was a wire there before either..
    but i looked at the foot control plug and it has 5 pins.. but only 4 on the machine!
    i have more pictures i took that are uploading now
    Mar 2010
    22
    pictures uploaded..
    i looked at the back of the connector..
    as you can see all the wires go somewhere.. doesnt look like there are any loose wires...
    the wire that runs down along the bottom of the welder connects to something on the other side
    Mar 2010
    22
    only thing out of place on the welder.. that i could see.. was this wire connector that didnt have a wire connected.. but who knows maybe thats how its supposed to be..
    May 2008
    Mpls, MN
    464
    Quote Originally Posted by buk View Post
    Wrong it is not, that is why there is a break down below the knob of how many amps you are running at each number. If you set it to 100 amps on dc when you floor the pedal to max you will get 100 amps but at half pedal it should be about 50 and so on. So if knob 4 is turned all the way up you are getting the least amount of control.
    Next thing you did not say what tungsten you are using, what gas you are using. So lets start there.
    With Sch 10 stainless I would set my amp knob at 70-80%, gas flow at 20CFH, us 3/32 red tungsten sharpened to a point. Is this what you are doing?
    One other thing did you make sure you have gas coming out of the end of the torch?
    -Dan
    Owner
    DW Metalworks LLC
    Miller Trailblazer 302
    Miller 8RC Feeder
    Miller Passport Plus
    Miller Dynasty 200 DX W/Coolmate 1
    Hobart Handler 135
    Hypertherm PowerMAX 30
    Smith O/A Torch Set
    Plus more tools then my wife will ever know about....
