Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: sharping tungen
  1. #21
    Nov 2007
    Appleton Wisconsin
    419
    Default how sharp
    The whole point to sharpening your tungsten is to reduce the cross section of the electrode. once the electrode becomes "saturated" with current the current will leave the electrode and be come the arc (Think of pinching or reducing the diameter of a hose). The arc transfers from the cross section of the electrode or the diameter. For how much to grind back I will refer you to the AWS welding handbook volume 2 8th edition page 82 where they graphically show the difference in the arc from a change in grind angle. When you do grind the finish should be as smooth as possible and ground back evenly all the way around. This will give you the best control and keep the arc coming from the point of the electrode and not the side.
  2. #22
    Indiana
    541
    This is what this sight is about. This is relevent info. All of the answers are good. Heck I learned something (as I always should, If I listen).
    Thanks to all.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
